Modding Mod design Opinions+Suggestions?
Discussion in 'Modding' started by Langer, 24 Jun 2008.
  1. Langer
    Langer Jesse Lang
    24 Jan 2004
    Hello again all.
    I've been busy planning and have come up with the following design.
    Some of you may have seen my original plans of adding a simple WC setup
    I've decided to get a bit more ambitious as I'll be living with my parents during some troubling family times over the next several months (some devistating illness' are currently plagueing my extended family), on a brighter note with home comes free access to a rather well equiped machine shop, located in my fathers factory.
    The plan is illustrated in the images below.
    A few caveats
    - the 9800GTX SSCs are going to be replaced with 3x280GTX SSCs due to stability issues with the 9800 series severely affecting my ability to work.
    - all construction materials will be 3/16" copper, 1/8" aluminum annodized black, and several widths of carbon fiber panels(as carbon manufacturing is the business my father owns)
    - fabrication of the larger peices will be done with a CNC router and laser cutter to ensure accuracy
    - diagrams below dont show the transformer bricks that will live in the drive bay to power the ALIX, PICO, and 7" touch panel
    *click for big*
    with labels
    ROUGH Parts List (TAX + shipping not included in prices)
    < = Purchased and owned
    X = Yey to buy
    Code:
    .................PART NAME..............................................PRICE
    SYSTEM#1
    CASE.............Lian-Li PC-A60C 10th Anniversary 294 of 300............0324.16 <
    PSU..............Silverstone Strider 1200W Modular ATX..................0299.99 <
    CPU..............AMD Phenom X4 9850 BE Quad Core AM2 2.5GHZ.............0265.62 <
    RAM.1............Corsair Dominator PC2-8500 5-5-5-15 4GB................0159.99 <
    RAM.2............Corsair Dominator PC2-8500 5-5-5-15 4GB................0159.99 <
    MOBO.............ASUS AM2+ M3N-HT Deluxe Mempipe 3-way SLI..............0290.45 <
    GFX.1............EVGA E-geForce 9800GTX SSC 770MHZ 512MB 2.3GHZ.........0375.75 <
    GFX.2............EVGA E-geForce 9800GTX SSC 770MHZ 512MB 2.3GHZ.........0375.75 <
    GFX.3............EVGA E-geForce 9800GTX SSC 770MHZ 512MB 2.3GHZ.........0375.75 <
    ..................................................................TOTAL 2692.11
    SYSTEM#2
    MOBO.............VIA ARTiGO Kit A1000 C7 1GHZ 1GB DDR2..................0334.02 <
    MOBO.ADD.ON......VIA Pico-ITX Video Card Module.........................0086.00 <
    RAM..............OCZ 1GB DDR2 SODIMM PC2 PC-6400 667Mhz.................0067.00 <
    HDD..............Fujitsu 2.5" IDE 5400RPM 120GB.........................0072.24 <
    LCD..............XDX 7" VGA Touch Screen TFT LCD 1024x768...............0195.94 <
    ..................................................................TOTAL 0755.20
    SYSTEM#3
    MOBO.3...........PCEngines ALIX.2C1 Kit 3x10/100LAN.....................0183.20 <
    WIFI.............Intel Wireless mini-PCIe 802.11N 300Mbps...............0059.00 <
    ..................................................................TOTAL 0242.20
    STORAGE
    DVDRW............Pioneer Slim 8X DVD+/-RW Slot Load.....................0071.99 X
    HDD.1............Hitachi 3.5" SATA 7200RPM 750GB........................0105.55 <
    HDD.2............Hitachi 3.5" SATA 7200RPM 750GB........................0135.76 <
    HDD.3............LaCie Neil Poulton eSATA 7200RPM 1000GB External.......0169.99 <
    HDD.4............LaCie Neil Poulton eSATA 7200RPM 1000GB External.......0169.99 <
    HDD.5............LaCie Neil Poulton eSATA 7200RPM 1000GB External.......0169.99 <
    HDD.6............LaCie Neil Poulton eSATA 7200RPM 1000GB External.......0169.99 <
    HDD.ADAPTER......2x 18" SATA to eSATA Adapter Cable.....................0006.11 <
    ..................................................................TOTAL 0829.38
    ADDITIONS
    SIDE.PANEL.......Lian-Li PC65 Black Stock Side Panel....................0045.00 <
    BLUETOOTH........Mini Nova USB Bluetooth................................0027.45 <
    RHEOBUS..........Zalman Plus Multi Fan Controller.......................0044.95 X
    LCD.2............Matrix Orbital GX Typhoon USB TRI-LED LCD 240x64.......0114.95 X
    CARD.READER......Logisys 3.5" Bay USB 52-in-1 Card Reader...............0009.99 X
    USB.HUB.1........Nexxtech mini 4 Port USB Hub...........................0009.99 <
    USB.HUB.2........Nexxtech mini 4 Port USB Hub...........................0009.99 <
    ..................................................................TOTAL 0262.32
    AIRCOOLING
    FAN.1............Scythe Ultra Kaze 120mm x 25mm 133.60CFM...............0011.99 X
    FAN.2............Scythe Ultra Kaze 120mm x 25mm 133.60CFM...............0011.99 X
    FAN.3............Scythe Ultra Kaze 120mm x 25mm 133.60CFM...............0011.99 X
    FAN.4............Scythe Ultra Kaze 120mm x 25mm 133.60CFM...............0011.99 X
    FAN.5............Scythe Kama-Flex 80mm x 25mm 34.0CFM...................0015.00 X
    FAN.6............Scythe Kama-Flex 80mm x 25mm 34.0CFM...................0015.00 X
    FAN.7............Scythe Mini Kaze Ultra 40mm x 20mm 4.86CFM.............0004.95 X
    FAN.8............Scythe Mini Kaze Ultra 40mm x 20mm 4.86CFM.............0004.95 X
    FAN.9............Scythe Mini Kaze Ultra 40mm x 20mm 4.86CFMMM...........0004.95 X
    FAN.10...........Scythe Mini Kaze Ultra 40mm x 20mm 4.86CFM.............0004.95 X
    FAN.11...........Scythe Mini Kaze Ultra 40mm x 20mm 4.86CFM.............0004.95 X
    FAN.12...........Scythe Mini Kaze Ultra 40mm x 20mm 4.86CFM.............0004.95 X
    ..................................................................TOTAL 0107.66
    WATERCOOLING
    PUMP.............Aqua Computer Aquastream XT Ultra USB Eheim 12 V.......0169.99 X
    RAD..............Danger Den Black Ice GTX Xtreme 360....................0124.99 X
    CPU..............D-TEK FuZion V2 Socket AM2 Waterblock..................0069.99 X
    RAM.1............Koolance Single Memory Liquid Cooler...................0034.99 X
    RAM.2............Koolance Single Memory Liquid Cooler...................0034.99 X
    RAM.3............Koolance Single Memory Liquid Cooler...................0034.99 X
    RAM.4............Koolance Single Memory Liquid Cooler...................0034.99 X
    GPU.1............AquaComputer aquagraFX 9800GTX Waterblock..............0125.00 X
    GPU.2............AquaComputer aquagraFX 9800GTX Waterblock..............0125.00 X
    GPU.3............AquaComputer aquagraFX 9800GTX Waterblock..............0125.00 X
    ..................................................................TOTAL 0882.90
    .................................................................NEEDED 1353.40 X
    ..............................................................PURCHASED 4418.30 <
    ..................................................................TOTAL 5771.77+TAX
    I'm curious as to what you all think of this 3 in 1 machine, the mod design, and the not yet purchased component choices.
    Anyone have any advice or design suggestions before I proceed any further?
    Thanks - Jesse
  2. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    That is quite complex
    I'd like to see it finished
