[MOD]:: DSIGN IV :: Dark Angel :: the best engraving of Jessica Alba
Discussion in 'Project Logs' started by niktard, 27 Jan 2006.
  1. niktard
    niktard What's a Dremel?
    21 May 2004
    ----------------- project log discussion --------------------
    http://forums.bit-tech.net/showthread.php?p=1166141#post1166141
    No !! you don't dream, I didn't finish the 3rd project ( DSIGN III ) that I realize some another, it's veryimportant for me because these is a PC which will be useful for my joint tenants whom used to steal my computer when they want to go on Internet while I would like to work with photoshop...
    So i find them a poor computer for 50$ :
    p3 550
    motherboard legend QDI
    2*128Mo pc 100
    grafic card S3
    HDD 3Go fujitsu
    sound card aopen
    lan card
    dvdrom
    floppy
    the case is a AT case , so i have to mod it in ATX, that's why i told me if you take your dremel you have to make another mod , you can't let this case original ! ^^
    the problem is i would like my joint tenants have a computer quickly , and i have decided to make another casemod, so it will take more time than if i had choosen to let the case like original !! ^^
    i think that i am doped !! lol
    Let me show you my first sketch, i would make something of simple, in black color ( i have found some acrylic black free... ) but i told me i could make all the surface engraved with white led.... i give to this project the name of " Dark angel " because :
    1 - it is in my order of casemod ( the two casemod first were japanese theme and the two other must be Angel theme )
    2- i had to find a name with " black " or " dark "...so " Dark Angel " like the movie, and i think you don't reproach me to use Jessica Alba as my model for the " angel "... ;)
    the front :
    - an engraving, a white vandal switch i didn't use, 2 white led with their chrome support, i didn't use too...
    on the right side :
    - an engraving of Jessica with her hand in the hair, the lines of the hair will be drawn on all sides of the case, so that will be homogeneous
    le top :
    - an engraving of Jessica who is lengthened
    scuze me to not really represant correctly how the case will look like but at 2.00 am i'm very tired and i don't have work as i would like on photoshop to show you better, and i have to translate all my text in english after , it's takes a long time to do it !! ^^
    the original case :
    bottom view without the hardware:
    we can see the few space inside to integrate all the parts !!So the first thing i have to do is to drill he first thing to be made was to remove the rivets to enable me to make a pass for my hand inside with the dremel
    vous voyez mieux avec cette photo !
    donc lon fait sauter les rivet :
    now I can use the dremel to cut a piece of the case which prevents to me from posing the motherboard in a flat position :
    I can use my files as I can so that don't look too ugly after cutting and can't hurt (for the cables at least), anyway nothing will be seen what there is inside since outside ( who wants to see a p3 550 and one S3??? )
    lol
    i increase this part, in order that my dvdrom can be in place...
    it's ok !!
    taht's all for today, tomorrow i will take all the dimension of the side and cut the black acrylic to pose it above each side of the case, then i will cut the transparent acrylic and engrave the angel who looks like to jessica alba ( maybe...or not ! ^^ ) and pose it abose the black acylic !
    and it will be finished for the casemod, not a lot of work, it seems not, but my previous project ( DSIGN III ) will take me a lot of time not to bungle my work !!
    taht's all for today ;)
  2. niktard
    21 May 2004
    just 3h of work today not more...
    the black acrylic with aluminium mesh inside :
    the acrylic 8mm, i use water paper P1000 to have a good transparency .
    i use my toshop pics in fullscreen not to make any mistake durin the engraving...it's a difficult exercise because le " white " line of your engraving is the " empty " in the scketch, not the "black " line of the pencil....i don't know if you see what i mean ?
    2hours later..
    :eek:
  3. niktard
    21 May 2004
    Project HTPC :: DSIGN IV :: Dark Angel
    Welcome to the DSIGN IV project log discussion. :dremel:
    If you have any questions, reproaches, or you want to tell me my work's good or at the contrary, it willl be better to make this , use this thread for !
    enjoy !
    :hip:
  4. Geheimnis
    Geheimnis What's a Dremel?
    3 May 2005
    i like this mod.
    the design is well, good luck for the continuation of mod.
  5. niktard
    21 May 2004
    i don't still engrave becausei found a new idea for the left side, how do you find it ??? let's see the result in 2h !!
  6. niktard
    21 May 2004
    a new update :
    je vais peut etre voir pour mettre des cornière alu noir...je me tate...
  7. Big SturL
    Big SturL What's a Dremel?
    15 Jul 2005
    As soon as I saw her, I gave your mod 5 stars. I believe that she is too hot for the public eye... Keep her in a confined space (preferably in my bedroom), and I will cool her down :D
  8. niktard
    21 May 2004
    thx for giving to this casemod five stars ;)
  9. nemesis80
    nemesis80 What's a Dremel?
    24 Aug 2004
    Cest du tres bon travail, continus comme ca, t'es un des meilleur(e) engraveur que jai vu jusque là!
    Nice work, keep going.
  10. Hybr1d
    Hybr1d Bаnned
    13 Dec 2005
    *drool*
    Alba is too sexy...
    And so is this mod. Amazing engrtaving skills there, and good choice of subject *wipes drool*
  11. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    I love those engravings man keep it up :D
  12. 5aboy
    5aboy Minimodder
    5 Oct 2004
    wonderful design, just wished i had enough time to do something to my boring grey box!!
  13. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    Awsome design! :jawdrop:
  14. niktard
    21 May 2004
    A lot of work today, i begin at 11' o'clock for cut the acrylic then i draw the stencil ( A3 format ) for my engraving at 12' o'clock and the since 13' then of 13h with 18h I do not have do nothing but engrave
    enjoy !
    the paper kit to polish ( P800 >>> 1600 ) :
    the engraving :
    OOoOOoooohhhh !!!! .....
    hmmm, it looks better than the others ;) i will engrave the other another time later...
    OOOOhh !!! doh it's so beautiful !!!!!!! [​IMG]
  15. niktard
    21 May 2004
    new update, thx for your coms guys, glad to see it a pleasure to you to follow the evolution of this casemod ;)
  16. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    You are a god.
    That is some truely impressive work, and you couldn't of chosen a better model ;)
  17. Veer
    Veer What's a Dremel?
    3 Dec 2004
    awesome engraving!
  18. ajampaniki
    ajampaniki What's a Dremel?
    14 May 2003
    Damn dude this looks extremely good. Wish i could design engravings like that. I still like the side cutout for your other case best, but this stuff is awsome 2.
    (if you have a cutout design like on the other case to spare that your not gonna use, you know where to find me)
  19. Klekkus
    5 Nov 2005
    Awsome work on the latest engraving, looks fu***** great!
    Looking forwards to the the final ressult of the case :D
  20. niktard
    21 May 2004
    my white LED have arrived , 4 pics of them, just for fun :
