Electronics Mod for my dad, opinions needed.
Discussion in 'Modding' started by Gascan1888, 14 Oct 2006.
  1. Gascan1888
    Gascan1888 New Member
    15 Dec 2004
    Okay my dad asked me to make him a flash light thingy, imatating This . he just wants the LED part to illuminate the blood trail, not the big xenon bulb. theres more out there like it, this is just the first i found with google. Now do you guys think those are just UV LEDS, with some red ones too ? i dont realy know if this will work, or how it works and just wanted your guys ideas. if you think it will work, im prolly gona mod it into a big Mag light.
  2. AJB2K3
    AJB2K3 New Member
    12 Dec 2005
    Im sure its just uv leds (Check out CSI), but i don't know for sure.
  3. Upriverpaddler
    Upriverpaddler New Member
    29 Jan 2005
    Google is very stingy on this subject. But I did find this little quote.
    "These Illuminator units provide a unique Blood Tracking Light System or BTLS. It is an array of four LEDs which form a multi-function light system,
    1. A single red light for a flashlight that will not disturb animals on the way to and from stands
    2. Three white lights for normal high powered flashlight use at night to see what is scanned
    3. Blinking red light in conjunction with the three white lights to make blood virtually jump out at you in the dark."
    This does kind of fit with the one you linked to. It looks like it has some white or blue LED's and one red one.
    You could get a good handful of blue, white, red, and UV leds for cheap. Then test the different kinds with the red one (blinking or not). Then after you figure it out you can mount them in something.
    You can get an LED flashlight from walmart and replace the bulbs in it.
  4. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    Mor ethan likely a UV array with red lights to. But it oculd be ultra high temp. light from the LEDs like uber blue-white light with flashing red in order to flash the blood and screw with contrast to make it really blow up. I think a 555 timer wired up right could flash red leds and an on off switch for both the white, UV, red lights w/e.
    blood contains phosphors so it will glow in the right UV conditions.
  5. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    I spent a few minutes trying to find reviews on the product, but without any success.
    Also, I really don't think that blood is UV reactive, but that's just a baseless assumption.
  6. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    I believe Upriverpaddler found your answer. (no UV involved - some of you watch too much CSI)
    Basic science says red things like blood reflect red light better than other things (like green leaves - which shouldn't reflect at all) except of course for white items which reflect all colours. The flashing red simply emphasises (sp?) red items - making them appear to flicker.
    Is there a store near you where you could try one out?
  7. Stuey
    20 Jan 2005
    Tyinsar conveys the explanation I suspect is true too, but the blue LEDs have a purpose too. Maybe they are used to oversaturate or essentially cancel out all of the other wavelengths the ground objects might reflect.
    It says they calibrated a specific spectrum - maybe the "red" LEDs aren't absolute wavelengths but specially selected to cover a slightly broader spectrum. I really don't think that there's a way to reverse-engineer something like this.
  8. Upriverpaddler
    29 Jan 2005
    Yes, google dosen't have much about what works, but plenty of places that say UV dosen't work.
  9. Gascan1888
    15 Dec 2004
    thanks guys, i didnt think it would be so easy ! i might have to go find one to play with to see how it works.
