[MOD] Glow the night
Discussion in 'Project Logs' started by *Shorty's*, 22 Oct 2006.
  1. *Shorty's*
    *Shorty's* What's a Dremel?
    1 Dec 2003
    Hi everybody,
    The first thing i want to tell to you, is: i'm belgian people and my english is not really great ;), so excuse me for the lot of errors ;).
    I've just finished my mod, so i post all pictures of the modding to you on the first post ;)
    The dislocated tower and painter tape for protect some parts
    My new 5 1/2" bay in lexan
    Painting finished for the interior of my case.
    NB: don't look at the middle of the motherboard tray, my paint will flow, so i've just scrape here, just for the paint not flow at the floor of the case
    Some thing for continous my mod
    A little test for the front paint on the plexi :) it's look :jawdrop:
    my case part, with first layers of primer
    some bondo just for the littles holes near the hole of my left wall
  2. *Shorty's*
    1 Dec 2003
    Part paint it matt black :D :blush:
    Black painting for the interior of my case too :cooldude:
    The result of lot of hours of work on my case :)
    Sorry for the quality of the picture but, it does not return the good colors. It really dark matt black on all side, the 2nd picture is the most realist for the color ;). You've certainly looked my left personal black lexan ;), i've made this with car solar film and my new windows on lexan cut with :dremel: :D.
    the interior finished :D :rock:
    You've certainly look the dvd player, but the front don't have hole for open her, it's just because my dvd writer is now on extern ;). On this picture the cathode isn't the good ;).
  3. *Shorty's*
    1 Dec 2003
    Now the front black painted lexan finished :)
    Some reflect ;)
    Global view[/img]
    The other side
    The inside with UV lightning look at this, so my picture dont look like the real color and lightning :waah:, is it awesome on real
    The real end of my mod coming soon ;) just adding little corner of aluminium at the front of the case for finished the look chrome/matt black ;), and adding 2 10cm UV cold cathode on the case for the other element who is reactiv to UV ;), and finally the sheath thermal for the enf of my sheath.
  4. ChiperSoft
    ChiperSoft What's a Dremel?
    27 Aug 2006
    I like the glossy full-face plexi, but how do you access your optical drive? Would've looked pretty slick if you had used a slot loading drive and cut a slot in the cover for it.
  5. crazylittleman
    crazylittleman What's a Dremel?
    13 Sep 2006
    You've done a really sweet job with that. The paint job is A+ and you haven't gone overboard with lights.
  6. *Shorty's*
    1 Dec 2003
    Thank ;) for the optical drive, i've said it's an external drive ;) on firewire ;)
  7. calib3r
    calib3r What's a Dremel?
    11 Jul 2006
    It looks very modern.
  8. low_violet
    low_violet What's a Dremel?
    5 Oct 2004
    Is the hard drive inside the CD enclosure? Can't see the point of having it there if it has no use... :confused:
    :idea: Hmm, may have to use that idea in my next mod. Never seen that done before.
    Looks nice btw!
  9. *Shorty's*
    1 Dec 2003
    yes the hard disk is inside the plexiglass bay ;) i've post a new picture of the interior this night ;) so just wait and see :)
  10. Noobkiller
    Noobkiller What's a Dremel?
    11 Jun 2006
    Dude whats the camera you're using? Because when I try to take a photo of something that glows in the dark, often times it is too bright or too dark.
  11. Jeet
    Jeet What's a Dremel?
    26 Oct 2006
    Did you paint the inside with Montana hardcore?
    Im sure it would work, but not my first choice for this kind of painting.
    So far the case look nice and clean.
  12. *Shorty's*
    1 Dec 2003
    yes i've painted the inside with montana hardcore ;)
  13. overdosedelusion
    overdosedelusion I mostly come at night, mostly..
    29 Oct 2006
    you should definately make a slot load DVD drive for added pizazz
  14. Evil-Inc-UK
    Evil-Inc-UK What's a Dremel?
    22 Sep 2006
    dude post more pictures of this case especially night shots if they are that sorta quality.
