Modding Mod Gone Wrong!!!
Discussion in 'Modding' started by dawson, 15 Nov 2001.
  1. dawson
    dawson What's a Dremel?
    15 Nov 2001
    ARggghhhh!!! help me pleaaasssseee!!!
    i have just finished painting my case (black) and i noticed there was some paint on my case window, so i put on some paint stripper, (the think gunk) and after rubbing it in, noticed it was all dodgy and white, so i tired to was it off.
    NOOOOOOOOO!!
    it never came off, the paint stripper has killed my window!! what will i do!!! help please!!!
    whats the best way to sort this?
    or will i have to get a new window?
    :mad:
  2. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Welcome to the fourm!
    It seems to me that you will need to buy a new window :(
  3. dawson
    15 Nov 2001
    gawd dammmmmmmit!!!!!!!!
  4. Slink
    Slink B7
    7 Oct 2001
    Hi replyed to this over on CCM where you posted it as well,
  5. IamChickenlittl
    IamChickenlittl What's a Dremel?
    25 Oct 2001
    where did you screw up the window? the whole thing...any pics
    there might be a fix but, we need pics
  6. dawson
    15 Nov 2001
    dont have a camera but its dead now, took a scouring pad to the window to save her, but she never made it. after a long and sweating 7 hour opeation, she trgically died. but im ordering a enw one from CCM, hopefully will fit (fingers crossed) but i dont know. god i love modding. lol. do CCM do black tinted windows?
    ~ d A w S o N
  7. IamChickenlittl
    25 Oct 2001
    You know for the info of others her you might want to try to use a clear sealant....just to see what happens....here is your chance to play around
    Either way let us know how it looks when done.
    Good luck to you.
  8. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    I sincerely don't mean to laugh at your misfortune dawson, but I can just picture it all going wrong and it getting worse and worse as you try to fix it, ending up in you sitting in a pile of rubble which was your house or something :D
    Bad luck dude, this should certainly go in the Disaster forum!! :)
  9. Tim S
    Tim S OG
    8 Nov 2001
    KNA, thats cruel, but true.... I have to agree, I've had some disasters in the last few days, with the main rig just seeming to screw up, and windows crashing good and proppa... and they say windows XP is the most stable OS from microsoft yet..... :confused: :rolleyes: :rolleyes:
    In this day in age, you have to be cruel to be kind, yes when windows crashed and I lost all of my coursework from the previous few nights it was annoying, but then you look at it from a light hearted point of view and it was kinda funny... :D
    Biggie
  10. RTT
    RTT #parp
    12 Mar 2001
    ive had XP for nearly a month now and it hasnt crashed once!
    honestly, its stable as a rock!
  11. Evilbob
    Evilbob What's a Dremel?
    28 Apr 2001
    If you havent wreked the whole thing you could always cut the window down and use it again in another case!
  12. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    or cut a fan hole in it over the affected spot (if it aint in a crappy lookin spot)
  13. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I wont hassel you over how you managed to get the window black ... but i guess that you have tried white spirits, brasso and every other chemical that has some form of restoration properties
  14. Slink
    Slink B7
    7 Oct 2001
    I think you shouldnt of used a scowering pad,
    Maybe a bit of mr sheen and a lot of elbow grease might have done the trick,
    Nice reply from Kna tho:rofl:
  15. dawson
    15 Nov 2001
    i used paint remover - yup, the thick gunk in a tin!! LOL!!!
    and i rubbed it in ALLL over, when i rinsed it under the tap, NOOOOO!!! ruined!! arg!!!
    but the ACE guys over at Cool Case Mods (the best mod supplier in the uk!!!!) have given me a new window kit for free, thats how kind they are!
    Cool Case Mods
    ~ d A w S o N
  16. Cheese
    Cheese Doc
    6 Oct 2001
    Why not try taking a dremel with a wire brush attachment on it to the window? You could turn it into a frosted window no probs :D Actaully had a good window recycling idea earlier but we might actually get 'round to doing it so if I told you now I'd have to kill you... sorry :)
    Cheers,
    r.
  17. dawson
    15 Nov 2001
    frosted window... nice!!! but i prefer clear, or even better.. tinted!
  18. funy
    funy What's a Dremel?
    23 Oct 2001
    heh so long as you dont try and install motherboard monitor, it totaly f***ed winxp, and it wont boot any more
    just locks up when starting
    and this includes when i try and boot in safe mode
  19. Hi-TEK
    Hi-TEK What's a Dremel?
    7 Sep 2001
    I use Motherboard Monitor with Windows XP and haven't had any issues. My LCD works perfectly running LCDriver, LCDCenter and MBM under XP. As Rich pointed out this new O/S is very stable once configured right.
  20. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    2 minutes and a Disk Sander and you got a frosted window :) for now
