Modding Mod ideas for this el cheapo case? (56K=OK!)
Discussion in 'Modding' started by SiMonTiST, 1 Nov 2002.
  1. SiMonTiST
    SiMonTiST Minimodder
    14 May 2002
    Here it is, in all its glory:
    Hehe, talk about a fire hazard! :D But of course, we modders don't crea about little things like that! :D
    Hehe and its nekkid :naughty: :worried: :p
    The case in all its glory!
    Another shot of teh case.
    Teh inside gutz!!1
    The front bezel.
    Maybe I should just use this case? It's got much better cooling, but it's quite noisy :D
    so, basically, this is my case. My best idea is to paint it all black, metallic bl00 or something inside, throw in a window, a cold caffode, and make the LEDs red. Anyone got any better ideas?
    Coz i can't think of anything original :wallbash:
  2. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    pics not working... maybe you should list them as URL's instead...
  3. SiMonTiST
    14 May 2002
    wierd... they work for me....
    is theforumisdown.com any good? Because that's what I'm using.
    :worried:
  4. cderalow
    cderalow bondage master!
    23 Jan 2002
    copy & paste eddie... its just like geocities
    or email them to me and I'll host...
  5. DeX
    DeX Mube Codder
    22 Jul 2002
    Yeah you have to copy them to the address bar. After that they load from the cache so that's probably why they work for you SiMonTiST.
    But I recon the only solution to beige box blues is to get a spray can out or vinyl dye which is supposedly pretty good.
  6. Milk Kid
    Milk Kid What's a Dremel?
    30 Oct 2002
    pics loaded fine here
  7. SiMonTiST
    14 May 2002
    okay, I've changed all the tags to [URL] tags.
    It might work now :eyebrow:
  8. DJMyst
    DJMyst yeah baby
    18 Jul 2002
    Hmmmm still not working. This is all I get. [​IMG]
    Check this thread First PC Mod Project and it shows what all I did to my completely bland and biege case. Might give you some ideas.
  9. Lazy
    Lazy Meow?
    13 Nov 2001
    nope its not working :(
  10. cderalow
    23 Jan 2002
    Simon... email them to me and I'll host for you...
  11. SiMonTiST
    14 May 2002
    thanks :D :clap: sending now...
    .EDIT. there, it's all fixed up now, thanks cderalow! :clap:
  12. cderalow
    23 Jan 2002
    should be sorted as soon as he edits....
  13. Milk Kid
    30 Oct 2002
    yep, they r loadin here np's, but then they were b4 aswell :confused:
  14. SiMonTiST
    14 May 2002
    Nice case, love the paintjob! :D
    I was thinking along the lines of something like that, only painted on the inside as well.
  15. Morphine
    Morphine weeee!
    23 Feb 2002
    sorry guys but im the one to blame for www.theforumisdown.com blocking this website :wallbash:
    I didnt read through their requirements a while back when we had a wallpaper contest and i had files that were twice as big as their limit :lol:
    soooo you can all hate me for that bright act of stupidity:D
    :nono: remember kiddies... always read the directions! :nono:
  16. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    Back to the subject... am I detecting a touch of Maplin Kit case there?
  17. wiLx u Up
    wiLx u Up What's a Dremel?
    22 Aug 2002
    Brush Steel Look?
    Custom windows?
    And get rid of that hideous front bezel. FAshion one out of smoked acrylic. That would look nice. And there you go.. nice case.
  18. SiMonTiST
    14 May 2002
    eh?
    Yes, that bezel is fugly. I have no idea how I would make an acrylic bezel, though, because the bezel on tis case clips on/off, and you need to take it off to take the sides off the case. :( :wallbash:
  19. wiLx u Up
    22 Aug 2002
    Get a hold of a piece of smoked acrylic. Cut it to the size of the front of the case and leave a lil over hang on the sides and top, about the thickness of your acrlic. Dremel out the slots for the bays and sand and buff. Get smaller strips to cover the sides where the front bezel used to cover on the case. That should fit all togehter correctly. The drill some holes in the case and acrlic and bolt the suckers in.
  20. SiMonTiST
    14 May 2002
    Good idea! :clap: Maybe thumbscrews would be better though..
