Modding Modding a be quiet! chassis part one
Discussion in 'Article Discussion' started by bit-tech reviews, 16 Mar 2017.
  1. bit-tech reviews
    bit-tech reviews Administrator Administrator
    10 Mar 2017
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    All the water cooled build terminology & parts required really do go way over my head.
    ..It really does sort the men out from the boys when it comes to Pc builds :)
  3. davido_labido
    davido_labido Your Alphacool Contact.
    11 Oct 2013
    Aaah, ok. How about I write a little glossary type article that can be edited and changed so that there is always something to reference?
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
    I like where this build is going:thumb:
  5. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    This should be good. Instead of painting the case to get it 'silvery', why not strip it and lacquer it?
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Will you go shiny-chromey or slightly-less-shiny-silver with the case? Will be interesting to see the use of silver and orange.
  7. davido_labido
    11 Oct 2013
    There is a lot of plastic on the case as well as metal, so it would be a lot more work and the finishes wouldn't match.
    I am going to try and go with a similar silver to the motherboard if I can, like a speckled titanium looking one.
  8. Jimmy6
    Jimmy6 What's a Dremel?
    19 Jun 2011
    Looking forward to seeing how this goes. I've got the same case for my first ever build, and whilst I do like it, the exposed PSU really annoys me! A simple PSU cover would make this case so much better.
  9. perplekks45
    9 May 2004
    Has it really been two and a half weeks already since you posted this? Damn....
Tags: Add Tags
