Modding Modding a Farnell LCD- how?
Discussion in 'Modding' started by xen0morph, 2 Feb 2003.
  1. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
  2. Middle of Nowhere
    Middle of Nowhere What's a Dremel?
    19 Jan 2003
    dont know about the led's, Id assume it wont be too easy but as far as the film, you can find links in the LCD faq or go to your local high end camera shop and ask them, they should be able to get some for you
  3. Cheese
    Cheese Doc
    6 Oct 2001
    You sure it has a backlight? I think the datasheet is misleading and it doesn't... think I had 5 of those once :)
    Rob.
  4. xen0morph
    30 Jun 2002
    If it dosen't have a backlight, is there a way to add one using LED's from the side?
    (or from the back? maybe using semi-transparent film?)
    The whole idea of the LCD is so I can see my system temps while playing Unreal at a dark LAN party :)
  5. Cheese
    Cheese Doc
    6 Oct 2001
    LED backlighting it will be hard. For side lighting you need something to make the light go forwards (a sheet of perspex with shaped cut into it normally) and for under LEd lgihting you need a sheet of leds in the colour you want that'll fit...
    The easiest way to add a backlight will be to mount some EL sheet under there. You'll get any colour you want this way, but I don't gaurentee the display will have good contrast if you use anything other than green.
    Rob.
