Electronics Modding a Nexus Fan Controller
Discussion in 'Modding' started by Sam0r, 10 Jul 2007.
  1. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    I've got a Nexus fan controller and currently even at the lowest setting the fans are still quite loud, and pushing more than an adequate ammount of air.
    It uses a 12v input, so I'm thinking of just doing the 7v trick on it so I get 7v out max and probably around 4v minimum, which would probably stop the fan (which is what I want).
    Will this work? Or am I likely to fry the whole thing?
    Cheers :)
  2. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    I dunno, but if it does blow up, take a photo!
    If you start out with 7V, it likely will drop down lower than 4V on the other end of the pot, meaning between 4V and 7V you'll lose a lot of speed control sensitivity.
  3. Skulldragger
    Skulldragger What's a Dremel?
    28 Jun 2007
    If you want to stop the fan can you not just put a switch inline to kill it?
  4. Sam0r
    24 Jun 2005
    Looking at the PCB it uses both 12v and 5v lines, so 7v trick isn't really possible.
    Instead I'm going to just add 3 diodes to the fan cables to lower the voltage by 2.5v
