Modding Modding my apartment. (Making a new door)
Discussion in 'Modding' started by Smilodon, 15 Nov 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
    I'll get the images hosted on a bit-tech server for you when I get to work.
    Tim
  2. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    They are hosted by us now. Good job on the mod! :thumb:
  3. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Looks awesome Smilodon! :eeek:
  4. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Thats bloody cool, i'd be shot for even suggesting something like that, but its still very cool.
    /thanks to bit for hosting them
    work blocks most of the normal photo hosting haunts and i usually forget by the time i get home so i would have missed this.
  5. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Ah! Thanks a lot! :D
  6. Danzel
    Danzel What's a Dremel?
    27 Nov 2007
    Thats cool, I plan on doing one soon with some friends. How deep do engravings have to be for the light to show? And what resistors did you use? Thanks
  7. Smilodon
    25 Mar 2003
    That depth depends on how much light you want to show. The deeper the cut is, the brighter it will glow. You should use this to your advantage. Use different depths on different details in the picture. This can help the image to look "richer". The body of the dragon and the knife part and parts of the handle is cut deeper than the rest of the image. It doesn't show to well in the pictures, though. I would recommend to going for about 1/3 of the total thickness of the sheet.
    As for the resistors, that depends on what LEDs you are using, how many you have in series and the power supply. You can calculate what you need here: http://led.linear1.org/led.wiz
    I really can't remember what values I used for the resistors, though.
  8. johnybutts
    johnybutts What's a Dremel?
    28 Nov 2007
    Glass
    Where did you get the glass/plexiglass and approx how much $$ was it?
  9. CanadianViking
    CanadianViking Beast from the North
    22 Nov 2007
    Looks awesome! Very much looking forward to any more projects you do in the future.
    And good on Bit for hosting those pictures for you. :thumb:
  10. YourmomNH
    YourmomNH What's a Dremel?
    28 Nov 2007
  11. Smilodon
    25 Mar 2003
    I got the glass at my local glass shop. (Pilkington) I can't remember the exact price, but i think it was about 1200NOK. (148.947€ / 221.312 US$) (this was for one full sheet of 3mm plexi and two sheets of 3mm glass cut to shape. (Buying plexi precut is more expensive, and I'm perfectly able to cut it myself. So buying the whole sheet were cheaper. Transporting a whole sheet of normal glass would be impossible, though...)
    That would work pretty good. The only problem is weight and thickness. You'd have to use thinner glass to be able to fit more layers. And you would then have to go for SMD LEDs. (Which are a PITA to solder without a PCB.)
  12. KeNalla20
    KeNalla20 Open to suggestions
    2 Dec 2007
    I'm looking at doing this just on a smaller scale.. where did you get your LEDs?
  13. Smilodon
    25 Mar 2003
    I got them at a shop called Clas Ohlson. I think they only exist in Scandinavia, though. They were a bit expensive, but getting them in a shop meant no postage. :thumb:
    Check out this thread for links to different online stores: http://forums.bit-tech.net/showthread.php?t=86806
    Shouldn't be any problem to find a store that sells LEDs. :)
  14. Guest-16
    Guest-16 Guest
    ROFL! This thread has had 130,000 views!!
    :eeek: :thumb:
    I'm so tempted to do a news post but I don't really know what to say and it's already been linked places :p
  15. nV7
    nV7 What's a Dremel?
    16 Apr 2007
    2 words: Holy sh!t !!
  16. CanadianViking
    22 Nov 2007
    Holy cow, I just noticed that now. :jawdrop:
  17. Firehed
    15 Feb 2004
    Wow... must be some kind of record, at least as far as hits per day go. I think we had a couple rare mod logs that were over 250k, but those spanned months if not years (can't say I follow the mod logs much anymore so I can't say for sure).
  18. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    I'm sure it's been said before but, DAMN THAT'S COOL!!!!!!!!!!!!!!
  19. Bex
    Bex What's a Dremel?
    3 Dec 2007
    I visited this thread via my 'stumble upon' toolbar. very cool work
  20. Smilodon
    25 Mar 2003
    The number of views have been pretty explosive the last few days. :)
    Thanks for all the compliments :)
    If you decide to do it just let me know, and i might have more pictures (/better quality) if you need any :)
