Modding modding noob lookin for ideas
Discussion in 'Modding' started by gnoff, 25 Oct 2003.
  1. gnoff
    gnoff What's a Dremel?
    25 Oct 2003
    ok, im new at this modding thing, and i need help thinking of ideas for a portable case for my computer. I know that i might sound kinda fool-heardy but i am looking for somithing challanging, to impress my friends and take to lan-parties. I really liked the ammo-case mod, but it was just too darn long for me to follow. I am kindof on a low budget too...
    Maby im comeing across a little demanding...so how bout I ask for fairly cheap ideas, that way ne1 who sees them can use them. :D
  2. LCDNinja
    LCDNinja What's a Dremel?
    22 Oct 2003
    the ultimate in portability would be a mini-itx system. Probably not very good for gaming though.
    Why not make one inside a suitcase or an empty toolkit? You could find one large enough pretty easy, and they're not that hard to mod
  3. Twernmilt
    Twernmilt What's a Dremel?
    23 Sep 2003
    If you don't know what you want to do and are just looking for something to put a computer in the best thing i can say is go to your local military surplus or salvation army/good will and just look around. I'm sure youll find something to your likeing.
  4. mence
    mence What's a Dremel?
    27 Nov 2002
    Go for a cube case with some handles on the top. Use cheap materials like scrap perspex for a good cheap solution. That way it's small, light and easy to carry to LANs.
  5. funkymunky
    funkymunky Guest
    i agree with mence... it'll let you get used to cutting perspex... so that if you decide to mod another case... uve already had some practise with cutting perspex... so u can do a range of stuff to the pc <-- if that all makes sence :lol:
    Rm :p
  6. gnoff
    25 Oct 2003
    thanks all for the ideas, i think ill go with a mod similar (although much eaiser) to the ammo box mod...I really liked all the lights and i have a really cool idea for a keyed start (like an ignition) that would be simple and pretty cool.
  7. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    My dad has some 20mm ammo cans that held 100 rounds, and I think I could fit my current PC in there case and all, so check around to find some larger ammo cans to try those. I've seen ones meant for mortars that were very tall, and so many other kinds, you probably could make a regular ATX system.
    It would be neat to se a full tower ATX stystem in an ammo can. Though all of it would have to be on an internal rack so you can pull the comp out of the can to get access to it..
    Good luck whatever you do.
  8. funkymunky
    funkymunky Guest
    yeh but isnt that going to be tricky?? that would involve making a frame inside of the ammo box... as well as making a frame for the casing to fit too..... good luck though!!!
    Rm :p
  9. gnoff
    25 Oct 2003
    lol, my last post was a little messed up, what i really ment to say was that im going to make a portable case (like an ammo case), and mod a key switch instead of a power switch into it. then i will hook my computer up to it.
    It sounds like it is still lacking somithing though...ne suggestions appreciated
