Ok, I want to get a Coolermaster ATC-110 ( a nice aluminum case ). I want to use my own custom design on the side of the case. I was wonder what’s the best type of tools to use, methods, and what should I use for the window ( Lexan or acrylic ). I don’t want to use any rubber to secure the window in place..... should I use an adhesive or bolts ?? Help ???
you'll need plenty of masking tape, helps to stop cracks on plexi, also if your wanting a tint effect on the back of the window, cool effect i think , you'll need window tint which can be found at the local car shop, for the windows i thought the chrome edging found here was pretty cool, but i don't know if they sell it individually, would have to ask them to find out
