Is it possible to remove these things and replace them with screws ? I want to do that on my lian li pc2 top bezzel, so I can remove it easy when the time comes to install 2 fans http://www.geocities.com/hydrogen2o/one.jpg please copy paste the damn thing I don't know what's going on with Geocities or Brinkster
If i understand you right you want to make the top panel removable yeah? If its like my PC60 then you just have to use a drill to remove the rivets and replace them with screws. Hope that helps :dude:
Look at the articles at Virtual Hideout, here is the link http://www.virtual-hideout.net/articles/project_tivoli/index3.shtml. That should awnswer your question. Signing out..
You dont have to use screws, you can go pick up a rivet gun thang and replace the rivets when your ready for your top panel to go back on. I think this makes your case look more professional and much better done.
