Other Mode Not Supported
Discussion in 'Tech Support' started by Roskoken, 24 Nov 2011.
  1. Roskoken
    Roskoken What's a Dremel?
    15 Jul 2011
    TV has decided it no longer supports HD from the 360. If anyone has a 360 and could do us a favor, could you tell me how to get to the HDMI settings to knock it of or down to a lower HD setting as i have no other TV or monitor, i pretty much need to do it blind.
    Cheers.
    No worries, problem solved!, GPU is dead.
  2. DevilsShooter
    DevilsShooter What's a Dremel?
    3 Nov 2011
    ack such a pain when that happens, had it happen to me changing from tv to monitor, as the console starts(use guide button) hold the yellow button then pull the right trigger to reset back to default so you can get on. at least thats how it used to work on my old xbox.
  3. Roskoken
    15 Jul 2011
    Aye its cool man, tried all that good stuff. Was playin skyrim at the time, graphics started artifacting, restarted xbox, mode not supported. Reckon the xbox itself is dead. OH WELL.
    **** it, just had a silverstone TJ08-E delivered this afternoon from scan. Only the graphics card to order and jobs a good un'.
  4. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    That's unfortunate.
  5. DevilsShooter
    3 Nov 2011
    ouch burnt out the hdmi/g card by sounds of it. small place in fife that repairs xbox's, nice turn around time too at just a week to repair if u ever repair it
  6. Roskoken
    15 Jul 2011
    Aye?, where about man?, just over the water in falkirk.
  7. DevilsShooter
    3 Nov 2011
    Roskoken likes this.
  8. Roskoken
    15 Jul 2011
    Ah good stuff, only 40 minutes on the motorway, cheers for the heads up good buddy!
  9. DevilsShooter
    3 Nov 2011
    np had a few faulty xbox's in my time :)
  10. Gaming_freak_10
    Gaming_freak_10 Minimodder
    5 Jun 2010
    Roskoken,
    What was your HDMI settings before it kicked the bucket?? sometimes the highest settings put too much stress on the 360's HDMI port.. try a lower setting like 720 or 1080i.. the 1080p is a bit too much stress. Mine is on the 720 and it'll stay there.
  11. Roskoken
    15 Jul 2011
    Aye well, ive had issues with that before, swapping monitors and all that to change, sometimes with samsungs in particular itll knock off the full HD, does it with PC's now and then too. But im pretty much blind, so trying to get to the video settings to set it to 720 is a bit of a nightmare.
    And together with the artifacting, weeeell. Fear the worse an all that.
