Scratch Build – In Progress "Model 01" [Final pictures and video!]
Discussion in 'Project Logs' started by Andreas | Brodholm, 13 Jan 2013.
  1. Andreas | Brodholm
    Andreas | Brodholm Member
    12 Jan 2013
    Welcome!
    I thought I would share a project I have been working on for a few years!
    I hope you will enjoy the log! :dremel:
    New to the log? :clap:
    You can easily get up to speed by checking THIS gallery!
    The gallery above is a compact version of the Full album with only some milestone pictures.
    Tip! Click a picture and you will get a zoomed view in the same window.
    Be sure to check out the thread after you are done and comment on what you think!
    You can also use the "View Author's Posts" function built into the forum.
  2. Andreas | Brodholm
    12 Jan 2013
    Sponsors
  3. Andreas | Brodholm
    12 Jan 2013
    Introduction
    Hello everyone, I have always been thinking about creating an account here at Bit-Tech but I never got to it. I have been browsing around here many times but never made an account. I have been over at XS for a long time and some of you might have seen me there. But now it is finally time to join you over here!
    And I thought, what better way then to do a build log here! Hope I am welcome here and that you will enjoy the log! :)
    History behind the design:
    About 5 years ago I decided that I was going to water cool my computer. Back then I had a Antec P180, not exactly the perfect chassis for water cooling your components. I looked at a lot of different chassis but I was never really happy with any of them. So I started sketching on my own design. First they were really awful, but as time progressed I got better and better at drawing. Early drawings was in MS-paint. I then moved on to Google Sketchup and finally Autodesk Inventor. I have probably gone through about 30 different designs until I finally decided on this one. This will be my first custom designed chassis and it will also be my first ever water cooled system!
    Goal:
    To design a chassis specifically for water cooling that is able to handle high-end components and still be quiet. And at the same time have a clean and stylish look that does not get old after a few months.
    Progress
    #1: Planning and Designing.
    #2: Constructing Parts.
    #3: Assembly of Chassis.
    #4: Completing Chassis.
    #5: Water Cooling.
    #6: Components.
    #7: Modifying
    #8: Installing and Testing.
    #9: Finishing Touches.
    #10: Final Pictures and Summary.
    Specifications
  4. Andreas | Brodholm
    12 Jan 2013
    Youtube clip of the laser cutter!
  5. Andreas | Brodholm
    12 Jan 2013
  6. Andreas | Brodholm
    12 Jan 2013
  7. Andreas | Brodholm
    12 Jan 2013
  8. Andreas | Brodholm
    12 Jan 2013
  9. Zsolt Guriga
    Zsolt Guriga New Member
    20 May 2012
    man this is perfect,and the rendering....i ve got no words to say
  10. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    I'm interested! loving the work so far
  11. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Nice work! Just be a little less... detached and professional, and you might get more comments :)
    i personally hate it when it seems more like a journal than a log.
  12. Rodrigo Vicentini
    Rodrigo Vicentini Member
    30 Apr 2006
    wow Nice word =D professional tools rules =D
  13. Andreas | Brodholm
    12 Jan 2013
    Thanks! Its really nice to have a good set of machines. Some of them are more or less only good for really big stuff.
    Thanks for the feedback! I really appreciate it! I know what you mean, Its a bit cold and detached right now. I will try and work on that! Maybe I should just use normal text instead? That makes it much less "professional" at least :D
    Right now there are catching up posts. But after the next post It will be "live" or what I should say. Usually I am in the workshop all day and when I get home I edit the pictures and present them this way.
  14. Axoxenon
    Axoxenon Do it right the first time
    28 Dec 2012
    Subscribed! Its always fun with some heavy machines ^^
  15. GotMod?
    GotMod? New Member
    3 Apr 2012
    Hi Andreas! Glad to see your project here!
    Keep up the amazing work! :dremel:
    Definately subd! )
  16. Andreas | Brodholm
    12 Jan 2013
    It's now "live" :D
    Next step is to sand everything down with 240grit paper and then glassblast everything. It will be interesting to see if I can manage to get an even surface :)
  17. vils
    vils New Member
    4 Jun 2006
    Very nice build. A bit jelous on your tech resources, I've built all my comps in the kitchen with hand tools...
  18. Si_the-dude
    Si_the-dude Techaholics Anonymous. 0 days clean
    17 Dec 2012
    Speechless. It's everything I've been looking for in a case. I'm really jealous of the tools and toys you have available :D Subscribed!
  19. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Damm. That CNC really kick a**. Nice work!.
  20. Julien Pod
    Julien Pod New Member
    23 Oct 2012
    Very promising !!!
