Modern browser for Athlon XP and Win XP?
Discussion in 'Software' started by Vault-Tec, 11 Sep 2017.
  1. Vault-Tec
    30 Aug 2015
    I kept getting IO errors trying to install 2k so I went with XP. I am not done yet, I will revisit it at some point.. I need a driver for the XP rig and I would rather have it on the net to find the driver as it's a royal faff keep jumping from PC to PC with a sodding memory stick.
    Is there anything that will work and connect to the internet for XP X86? I've tried but come up empty handed. I tried a fairly recent Firefox but it moaned about SSE2 or something then exited. The IE on there won't work on any websites.
  2. yodasarmpit
    yodasarmpit No longer the other Brett.
    27 May 2002
    I believe Opera 36 is still supported, and works on XP.
  3. RedFlames
    23 Apr 2009
    Firefox ESR, though the current version [v52] will be the last to support XP and vista.
  4. adidan
    adidan Too lazy to change avatars. It's always christmas.
    25 Mar 2009
    Netscape Navigator seems appropriate :)
    Looks like there is Slimjet that is based on Chromium - never used it and don't know much about it but may be something to look at if you like your chrome extensions.
  5. yuusou
    yuusou Active Member
    5 Nov 2006
    Don't like being that guy because of stigma but at this point... wouldn't it be easier to just put some linux distro on that?
  6. Vault-Tec
    30 Aug 2015
    Nah that's fine dude. It's a retro gaming system to run Direct X 3 games. So I think Linux would come a bit unstuck.
    Any ideas where to get it?
  7. RedFlames
    23 Apr 2009
    here
    Vault-Tec likes this.
  8. mrbungle
    20 Sep 2004
