Case Mod - In Progress Moding 380t from ITX, into mATX
Discussion in 'Project Logs' started by Lehani, 12 Mar 2015.
  1. Lehani
    Lehani What's a Dremel?
    27 Jun 2012
    hi there.
    i have cast my love on the corsair 380t, but i have a mATX, not ITX. so what does i real modder do ? MOD IT!
    so let us start.
    here it is.. lets strip it apart :)
    done :)
    now lets cut a little :)
    well, i have to make a whole new backside plate, thats why i leave 0.5 cm so i can use some rivets.
    now i only have to figure out how thick the new plate should be, i am thinking about some 0.8mm plate. but lets see...
    and i also need to find another mATX case, also need to find a way to place my powersupply
    a fine start of the project :) please feel free to leave comments, and suggestions :)
  2. Impatience
    Impatience Minimodder
    6 Apr 2014
    *Subbed* I've always thought there was wasted space in this case! Let's see what you make of it! :thumb:
  3. Lehani
    27 Jun 2012
    Corsair's 380t Black and white concept
    well. another day in the life of a modder :)
    i have an idea of making it black and white, since i will have all red LEDs changed into white.
    i have change all the riverts and used new white ones, mainly becuase i dont have any black, and alot of white. so instead of have some of them white, i took a decession to make them all white. now the case was seperated :)
    i had a old Fractel design define mini:
    kill it :)
    so it goes the right way. the backside from the fractel case fitted like a charm :) so i hope next week i can get the back, cutted and rivert into place :) good weekend :)
  4. Arboreal
    21 Jan 2011
    Great idea, the 380T really is large for ITX, cramming in a mATX kit is the best thing to do with it.
    Will be watching with interest.
  5. Lehani
    27 Jun 2012
    thanks :) i this morning i notice a little ekstra piece that needed to be cutted :) so i have some work to do before monday, where i get my backplate :)
    furthermore i have placed an order: [​IMG]
    a nice touch to the mod :)
    on the last picture in the previous thread you can see 2 long stiffeners, normally you can put 2x120mm fans up on those, i will make use of those with, one fan for GFX, and one fan for CPU.
    since i will be using the silverstone tundra td03 water cooling for my CPU.
  6. greenfarm
    greenfarm What's a Dremel?
    6 Mar 2015
    Where can I buy this power adapter?
  7. Lehani
    27 Jun 2012
    the picture is from ncases.com, where they sell it :) for 10USD i think it is. but the shipping cost is way to high for me, so i found it at the local hardware store :) for the small amount of 5 usd :)
  8. Lehani
    27 Jun 2012
    Update on my mod once again :)
    i got the plate from the local workshop yesyerday... i started to cut, measure, cut.. and make it nice :)
    alot of mess :) but the end result is really going to be nice :)
    i threw the motherboard in place :) looking fine, even got some room for a little cable management :)
    enjoy the pictures :)
    now i beginning to think where i put PSU :) and my CPU cooling :p
    i noticed that i forgot to cut a little corner :( but is it nesscary ? i think i will put a few thoughts into it :)
    and the big question is, the CPU cooler? should be be in side or in the back?
  9. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Not bad, quite roomy case then. I thought you would have needed it to do it diagonal.
  10. Lehani
    27 Jun 2012
    diagonal ? :) no, its have like 1 cm on both top an bottom of the motherboard :)
  11. Lehani
    27 Jun 2012
    well been paint and cutting :D tomorrow i hopefully got some pictures of the case, where i hopefully start to gather the case back together.
  12. Lehani
    27 Jun 2012
    the last part of it :)
    well... i got painting and cutting :) and the case are coming together as a whole PC once again :)
    well, i am happy with it myself :) just hoping that corsair gets thier minds open and make a mATX
    enjoy it :) the hardware comes on monday i hope :):)
    it wasnt that difficult to mod to fit mATX :) i hope someone else will do this so Corsair gets thier eyes up for the mATX size cases.
    comment are more than welcome :) i'll be posting a another shot with the hardware stuffed inside :)
  13. storm4710
    storm4710 What's a Dremel?
    24 Mar 2015
    nice m8
    going to do something like it to my 380T will post pictures when done i have a month to make room for a mATX motherboard 240mm AIO Corsair system and a GTX 780
  14. storm4710
    24 Mar 2015
    now i did it
    Hey m8
    finally had some time to do it
  15. Lehani
    27 Jun 2012
