Case Mod - In Progress Mods By Donnii - ThermalTake P5 Frosted tubes
Discussion in 'Project Logs' started by Donnii, 3 Feb 2016.
  1. Donnii
    Donnii Mods By Donnii
    15 Jul 2015
    So here is a new build log from me, i will start this project with some sponsors who helps me to make this possible so lets start by listing them here!
    All watercooling parts are from Aquatuning, Great guys :p A big thanks for the support!!!:
    • Alphacool NexXxoS XP³ Light - Brass Black Chrome
    • Alphacool NexXxoS Monsta 480mm
    • Alphacool Eisbecher D5 250mm Acetal
    • Alphacool VPP655 - G1/4 inner thread including Eisdecke D5 - Acetal V.3
    • Alphacool HT 16mm HardTube compression fitting G1/4 for plexi- brass tubes (rigid or hard tubes) - knurled - deep black
    • Alphacool HardTube 16/12mm plexi clear 80cm - 4pcs
    • Alphacool connection terminal TEE T-piece round, G1/4 - deep black
    • Alphacool L-connector 90° - G1/4 revolvable - 2x inner thread - Deep Black
    • Alphacool angled adaptor 45° - revolvable - G1/4 outer thread to G1/4 inner thread - Deep Black
    • Alphacool angled adaptor 45° - G1/4 revolvable - 2x inner thread - Deep Black
    • Alphacool Eiszapfen 2-way ball valve G1/4 - Deep Black
    • Alphacool Y-45° connector - G1/4 revolvable - 2x inner- 1x outer thread - Deep Black
    • Alphacool double nipple G1/4 outer thread to G1/4'' outer thread with O-ring - deep black
    MSI Sponsored there MSI X99A Mpower for a high quality Motherboard to go with the Intel i75960x
    Next Sponsor is Noctua for them cool Industrial PPC NF-F12 PWM fans:
    • 8 x Noctua Industrial PPC NF-F12PWM 2000RPM IP67 With white corners for all
    Next one up is Be Quiet!
    • Be Quiet! Dark power Pro 11 - 1200W
    OCZ With SSD's
    This is the Sponsors so far.
    _______________________________________________________________________________________________
    The Build is going to be in a ThermalTake P5 case with some modifications to it.
    Hardware will be folowing
    MSI X99s SLI Pro
    intel I7 5960x
    64GB of Kingston DDR4 2800Mhz RAM
    OCZ Revodrive 350 480GB
    Kingston Predator M.2 SSD 240GB
    MSI GTX960 4GB ( Later on my GTX980 TI will go ind it )
    Broadcom 2 x 10GBps NIC's
    So lets start by looking at the things i got so far :rock:
    First package @ 3-Feb- 2016
    Next up is some pictures off some off the parts :brrr:
    Over and out for now guys have a good one :thumb:
  2. Donnii
    15 Jul 2015
  3. coalminer071
    coalminer071 New Member
    10 Sep 2015
    Impressive set of parts you got there, looking forward to the build.
  4. Donnii
    15 Jul 2015
    Thanks :) i really look forward to see it done! I have some new pictures today :clap:
  5. Donnii
    15 Jul 2015
    Update 5/2/2016
    Today i got the ThermalTake P5 case, really cool case!! so here is some pictures of the build so fare :)
    :rock:
  6. Donnii
    15 Jul 2015
    New update 08-02-2016
    New package from Aquatuning just arrived :clap:
    This time its a PWM splitter, LCD display, bending tools.
    /Donnii
  7. Donnii
    15 Jul 2015
    Update 10/2/2016
    So now im working on some panels to make it all clean and nice :)
    I still nees some things to come home, but the most parts are here now, so now i need to get startet on CNC these panel :rock:
  8. Donnii
    15 Jul 2015
    Update 11/2/2016
    Yet a new update! Today i got some CNC work done and got the Leather on the panels, looks pretty cool i think :)
    Here's some pictures :rock:
    /Donnii
  9. Wrathier
    Wrathier Member
    3 Feb 2016
    Great job bro :)
  10. Donnii
    15 Jul 2015
    Wuhuuuu New CPU
    Today i got my i7 5960X for this system :clap:
    /Donnii
  11. Donnii
    15 Jul 2015
    Update 12/2/2016
    The i7 5960x is up and running in a test loop to make sure its all like it should be :) A lillte ghetto, but it work for now :clap:
    /Donnii
  12. hovek
    hovek “Can’t or won’t?” Sterling Archer
    23 Jan 2014
    Like the backplate! It sure is an interesting case, just think the standoffs are a bit too long, no?
    How's that Kress 900 you're using? I'm thinking about building a small 50x50 cnc with it. Is it very laud with no load?
  13. Bartacus
    Bartacus Member
    30 Oct 2014
    I love my P5, TT hate be damned. :) The one thing I can't figure out though is why people always mount the 480 rad with the ports on top. I much prefer mine on bottom for draining purposes.
  14. Donnii
    15 Jul 2015
    At full speed it makes some noise but i dont think its to bad :)
  15. Donnii
    15 Jul 2015
    This Rad does have a hole in the bottom to :)
    The reason why i mounted it that way, is not to get ait trapped in there :)
  16. Bartacus
    Bartacus Member
    30 Oct 2014
    DOH! Oh yeah, now I see the drain valve. I somehow missed that! :wallbash:
  17. Donnii
    15 Jul 2015
    Hehe yup :)
  18. Donnii
    15 Jul 2015
    Update 18/2/2016
    So today i got the last package with Water parts, Now i can get more doen on the build :)
    /Donnii
  19. Donnii
    15 Jul 2015
    Access for pump speed
    By default ThermalTake havent made a hole for ajusting pump speed, i need it so i made a access hole myself :dremel:
    /Donnii
  20. Donnii
    15 Jul 2015
    New update 19-02-2016
    So today i played around with the tube bending and its going to look something like this, im not sure if im happy with this yet, so ill try out some other runs to i think!
    More to come :rock:
    /Donnii
