MODS PLEASE LOCK - MOVED TO NEW FORUM :D!!!
Discussion in 'Project Logs' started by Starbuck3733T, 2 Sep 2003.
Thread Status:
Not open for further replies.
  1. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    where did you get that cpu wc head
  2. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Great work! Love to see well bought products in a craftmanshiped mod. A waterblock for 200$ is quite insane in my thoughts, but it makes a really good tuch to your system!
    Wich I could stand besisde that thing and look on it for a while :thumb:
  3. obzelite
    obzelite What's a Dremel?
    9 Jun 2005
    is it just me or is KustomPC.co.uk redirecting to M$ site?
  4. Nexxo
    23 Oct 2001
  5. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    http://www.employees.org/~slf/lrwb/
    And razor_cut is right, it is insane, but its an amazing block. Full load temperatures only 5*C higher than idle.
  6. Starbuck3733T
    16 Sep 2002
    Part I: Lighting placement and routing
    Top white CCFL with Reservoir's UV inverter hidden up underneath the frame, and drain tube from res.
    Bottom UV CCFLs, 2 of them. They're zip tied together, and then to the case frame. I discovered that with the way the doors attach to the case, that I can actually zip tie into the structure and not interfere with the mating surfaces.
    Bottom UV CCFL inverter. I dare you to find the wire that goes back up to the top bay from the inverter!
    Top white CCFL inverter tied to front of the frame, with the drain nestled beside it. Yes, the drain line is hanging out a bit, but it'll be pushed in by the side of the case when it is installed.
    Rear UV CCFL inverter and a bit of the top white CCFL. The rear UV CCFL is sitting above the exhaust fan, you can just barely see the end sticking out above the exhaust fan.
    Play spot the inverter. You can also see (more clearly this time) the top rear UV CCFL above the fan.
    Part II: I'll shut up and let the pictures do the talking...
    ...with the occasional caption.
    (and this is why I ran with the white barbs, they glow!)
    (Looking down from the rear)
    (Splitter)
    (G5 in and out)
  7. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    looking forwards to this update!
    but.. server troubles? o_O
  8. BlackMan
    BlackMan Minimodder
    12 Sep 2003
  9. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    the pictures arent doing any talking :(
  10. Nexxo
    23 Oct 2001
    You forgot to turn on your PC speakers again. :p
    OK, stop! That PC is just too juicy for general audience viewing!
    :D
  11. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I'll second that :jawdrop:
  12. Starbuck3733T
    16 Sep 2002
    They hosed up their routes in one of the cisco routers and the web server couldn't serve off the PASS space, therefor pix were down. Sorry!
  13. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    Little bit a mess from inside! but not that big!
  14. Starbuck3733T
    16 Sep 2002
    Mess, what mess? where? Seriously. You're killing me here!! :eyebrow:
  15. Starbuck3733T
    16 Sep 2002
    Reservior Lighting
    From the front:
    Dark shot. Silver things are the plug and cool G1/4 returns.
    Closeup of the backside of the fititngs:
    The light source:
  16. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    @ Pitbull: Yeh, there are a hole lot of cables and stuff in there... but well, it's water cooled, what did you expect it to look like? You can't hide the /wc stuff. o_O
    @ starbuck: Very nice work man. Good looking res btw.
  17. HilRam
    HilRam What's a Dremel?
    22 Apr 2005
    I'm excited to see how this turns out. What happened to the tribal-theme window?
  18. Starbuck3733T
    16 Sep 2002
    Changed my mind, pure and simple. Window and paint designs always take me a long, long time to figure out, since there's no going back.
  19. madhatter
    madhatter What's a Dremel?
    16 Sep 2003
    Really, really love your idea for the buttons and the IC on the board for controlling fans, lights, and ATX.
  20. Starbuck3733T
    16 Sep 2002
    Thanks. I really must get back into that part of the project. Maybe I'll work on some of the buttons tonight... Need to get them sleeved up and glued in. Hrm... It's been so long since I've messed with the controller board prototype that I barely remember what it does. :lol:
Thread Status:
