Guide Modular PSU made at home
Discussion in 'Modding' started by Darth Invader, 5 Jun 2007.
  1. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    First off. GREAT IDEA. But i personally wouldn't have cut the 24 pin since your always going to use it. other then that this is a quality mod and i wouldn't mind doing it to an old psu. It's just to flashy with the acrylic and fan grill etc, i like plain psu. still love the idea.
  2. mod-zoo
    mod-zoo What's a Dremel?
    20 Sep 2007
    Wow, now that's really kewl. Now to find a "test" subject. :naughty:
  3. Rocks7ar
    Rocks7ar What's a Dremel?
    30 Sep 2007
    Do you have any stability or current issues? Any ripples?
  4. DSquareD
    DSquareD What's a Dremel?
    24 Nov 2005
    do u think that making a modular PSU will help the cause of powering LEDs and lighting and such?
    in my mod i plan to either use 2 PSUs, one for components and one for LEDs, lighting, fans, etc, or to use one PSU and then make a junction box for powering other things...which is a better option?
  5. whodareswins89
    whodareswins89 What's a Dremel?
    14 Sep 2008
    Great Job! Looks Good!
  6. Torched-Geek
    Torched-Geek What's a Dremel?
    28 Oct 2008
    I think i'm going to buy a premade modular PSU for my next machine, if I had the balls to mess with this kind of stuff i'm sure i'd use this guide. :jawdrop:
  7. rainwulf
    rainwulf What's a Dremel?
    12 Jan 2004
    Another one for the current rating on DB25. They are signal connectors only.
  8. Urgonath
    Urgonath The one and only Urgo
    11 Jul 2008
    Sweet PSU mod there. I have now got plans for something very similiar for my not so old OCZ GameX Stream, should be fun and free up loadsa space in my older PC.
  9. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    nice work! I like the 4pin connectors and the Plexi cover. My only quibbles are the somewhat sloppy sleeving and heatshrinking on the cables themselves and that 24pin connector (DB25).
    I did a quick google, and AC ryan sells both the male and female versions of the ATX 24pin connector (aka: EPS12V, ATX-GES) I'm sure you could find them elsewhere as well, of course.
    Oops... aided and abetted ancient thread revival.
  10. benji2412
    benji2412 <insert message here>
    25 Apr 2009
    Inspiration on a stick! Nice one mate
  11. Fiyero
    Fiyero Vindaloovian
    20 Sep 2009
    Awesome mod which I am definitely going to have a go at.
    I do have one worry though, is there likely to be any residual charge left inside the PSU when you take it apart?
    Anything you should do your best not to touch etc?
    I've got an old one that's not been powered up in probably 2 years now, it's been sat in an old case gathering dust. I've pulled the casing off, now just worried that if I touch something i'll give myself a new hairstyle!
    There's a lot crammed into a small space, it'd be easy to catch something.
  12. stonedsurd
    11 Mar 2009
    Besides the 24-pin scaring the bejesus out of me, that's a CRAZY mod! :clap:
    Great job!
  13. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    Hah, Darth Invader, you ninja'ed me! =)
    Been working on the same thing, with the same plugs, but going a bit differently. I'm leaving the Mobo power as-is (read: too lazy to solder all those pins.) But I'm putting the couplers in their own seperate breakout box and using bronze thrust-bearings to give it more 'pop'.
    I'm kinda glad to see your PSU had enough room to put it all in the case - good job with the plexi BTW.
  14. sejutaluka
    sejutaluka What's a Dremel?
    23 Nov 2007
    Great Job! Looks Good! It's inspirational..
  15. Krog_Mod
    Krog_Mod What's a Dremel?
    23 Sep 2003
    Simply awesome.
  16. Elton
    23 Jan 2009
    About the concerns on the DB25, did you run into any issues with it? (Holy thread revival)
    Couldn't you have just opted for a female 24-pin?
