Case Mod - In Progress MODZERO ASHEN - PARVUM SYSTEMS X3.0 CUSTOM
Discussion in 'Project Logs' started by HackJoe, 25 Jan 2019.
  1. HackJoe
    HackJoe Active Member
    29 Jun 2011
    Wow, the last year has flown by! I finished the MODZERO JUICE build logs back in December 2017 and then went dark...
    I'm still running my S4 Mini daily, I love it! and it's been great at LAN events. Though I'll be retiring it when ASHEN is complete, fear not, it won't be boxed and stored. JUICE will be back later in the year as a fully (internal only) water-cooled S4 Mini (MODZERO JUICED).
    MODZERO JABBA was meant to be next, and it will be, after this one. ASHEN came about whilst talking to the Parvum Systems guys over the JABBA design (Custom X2.0). I'd recently bought a Filco TKL (MX Blacks) and bought these keycaps, SA ASHEN FROM MAXKEY (here). They look awesome! but didn't really suit the aesthetic of my S4 mini... so... yeah.. I'm building my keyboard a matching computer.
    Shaun at Parvum talked me into it when he showed me just how close their acrylics (stone grey, dark grey) would match. JABBA is an X2.0 but I knew Parvum had been working on the X3.0 (see JR23 Chocolate box)! I'm a huge fan of JRs work and thought this a good little project to work with a design of his (mostly).
    So Shaun did his Parvum magic, pulled up the X3.0 design and went about making the changes I'd need and even adapted the custom pump mount/res you'll be seeing again in JABBA.
    As the build progresses you'll get a clearer picture of how the X3.0 differs to the X2.0 (If you're into it). But, in a nutshell, the HDD mount panel is gone, the SFX PSU is now up at the top (2x 2.5" drive mounts on the bottom panel), new front panel design (I opted for a three-panel variant), New top panel design (grill over the rear chamber, window over the GPU) and possibly a new GPU mount (it's certainly different from my old Veer but that's old old).
    So the plan is simple enough, I had a custom mid-wall panel designed for a really clean finish. the integrated DDC mount/res is stunning! and frees up so much room! so I'll put a CPU loop in that takes the loop into the rear chamber and hooks up with the RAD. I'm hoping to archive some really clean lines.
    I went with MDPC-X sleeve this time around, props to my man James at PexonPCs check him out for all your MDPC-X cable supply needs.
    This is my first build with support from EKWB! I'm super excited to have these guys on board! they have always been my number one choice for blocks and with the great looking EKWB - Velocity D RGB AMD going in this build, I can't wait to do them proud.
    I've plenty of product shots up on my Instagram and will post more in the logs are things progress. It's an absolute pleasure after years of building to have support from some of the biggest players. This isn't a carrier path for me and has always been a labour of love. I'll maybe build one PC a year (if I'm lucky), I'm a hobbyist at best. But when I had confirmation that AMD would support ASHEN, I lost my s**t!.
    The first custom PC I built for myself out of my own pocket ran an AMD Athlon XP1500+. I was maybe 18 years old, I had a buddy in Florida that was able to pick the chips from a stock bin and we'd get the ones known for their stepping. Overclock the life out of them and they'd post as an XP2100+. AMD made a product I could afford, which enabled me to build a PC and become a part of the PCMR, the quest for higher performance from my purchase led to aftermarket coolers, better fans, case designs, water-cooling and thus ultimately it had its part in MODZERO. I'll try and find a photo of that machine... I'm sure I have one, for the time it was badass!
    Gigabyte UK has had my back since MODZERO OCTO, I got in touch about this project and they showed me the love. RTX ON. Really enjoying how the mobo, ram and GPU all share the same design elements.
    Free time is hard to find at the moment and this build is taking it all and then some. I really wanna get this one turned around fast. It's taken a long time to put all the pieces on the table. I'll be posting build log updates weekly (fewer studio shots and more process ones) until it's finished.
    I can't wait to show you more. Thanks for checking this out.
    J.
    Hardbox likes this.
  2. EKJake
    EKJake EK Forum Rep
    23 Oct 2018
    Looking forward to this! <3
  3. HuguesP
    HuguesP New Member
    18 May 2018
    I am in
  4. HackJoe
    29 Jun 2011
    UPDATE 2.0
    I've been hacking away at this with every spare 15-20mins I get (and with a 16 months old boy... that ain't often). It's coming along nicely. So I wanna bring you up to speed. Cables and distro plate are up first.
    I went with MDPCX sleeve with this one, if you're in the UK go check out Pexon PCs they sell the full MDPCX lineup. I pulled the colours from the ashen keycaps.
    MDPC-X Haze Grey
    MDPC-X Titanium Grey MK2
    MDPC-X Diamond Red Small
    I approached the wiring differently this time around. With all my previous builds I'd take a length of wire, rough measure, cut, crimp both ends and repeat for all wires.. THEN sleeve. This time I listened to a master and did as instructed. Check out p0pes guide to perfect cables.. it's the only video you'll ever need.
    I've gone off combs tbh but these are really low profile and seeing as the mid-wall panel is cut for each wire they made sense at least for the GPU.
    When you only have 10 minutes here and a half hour there, wiring takes an age! haha, slowly I got them all done.
    Next up (well, before I guess) I tackled my distro-plate/ ddc pump mount/res. I'm not too great with a soldering iron and replacing the factory wires on the DDC pump is the best way if you after a super clean look.
    Instead, I stripped it back, put some tight shrink wrap on each cable, fitted the new EK housing and sleeved the wires directly into a 6-pin on the PSU.
    This scared the **** out of me. It's taken a while to get all the parts together for this project and I couldn't help thinking if I made a mess of the plate I'd be in for another delay. It came pretty rough cut from the Parvum boys and after a quick chat with MADS.ONE I knew I was in for some arm ache!
    250 grit
    500 grit
    700 grit
    1000 grit
    1200 grit
    1500 grit
    1700 grit
    2000 grit
    2500 grit
    3000 grit
    5000 grit
    7000 grit
    All by hand, it's far from perfect.. annoyingly I just couldn't get into some of the spaces with my fat fingers but overall, it's not too shabby.
    I ordered some 18mm M4 bolts for the pump mount as the supplied ones are designed for a pump top and would have cracked the plate (too long). rigged up a quick bend and leak tested. I made a mistake here.. I left it running for a while... and lets just say, it got a bit hot! oops.
    I'm so excited to be back on an AMD CPU. It's been too long. Must admit, a part of me wants THREADRIPPER!
    That EK VELOCITY block looks great! Normally I've planned the loop out well in advance... but with the build, once I'd decided to pass-through the mid panel I thought the rest would just fall in place.
    I was wrong...
    Next update will be the loop (version 1).
    It's gonna be goooooood, thanks for checking this out.
    J.
