Modding Molex Pin Extraction (female)
Discussion in 'Modding' started by TwiSteD LoGic, 20 Jan 2004.
  1. TwiSteD LoGic
    TwiSteD LoGic What's a Dremel?
    1 Nov 2001
    I was just wondering if anyone had a good method for removing female molex pins from the plastic pieces w/o spending 15 bux on a molex pin extractor.
    Thanks alot. =)
  2. The_Sub
    The_Sub What's a Dremel?
    16 Nov 2003
    Use a paper clip or a really small screwdriver to bend in the little tabs just a bit. The wire should just pull right out of the connector..
  3. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
