Electronics Molex to LED
Discussion in 'Modding' started by scq, 17 Aug 2006.
  1. scq
    scq What's a Dremel?
    4 Mar 2005
    I have this 60,000 MCD led rated at 2.2V @ 100mA.
    Being a complete electronics newb, any idea how I can easily hook this up to a 4 PIN molex connector as a cheap light source for case lighting?
  2. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    You are going to need the proper resistor to convert the molex from either 12v or 5v into your LED's input of 2.2v
  3. scq
    4 Mar 2005
    That's it?
  4. Warrior_Rocker
    26 Jun 2005
    yea pretty much the molex is something like
    () | +12v (yellow)
    () | Gnd (black)
    () | Gnd (black)
    () | +5v (red)
    So if you can find the resistor to convert it from either 5v or 12v, you can find the proper resistance by using the formulas or a calculator, if you have the Male End of molex you can just solder the wires directly to that connector, and just plug it in wherever you want a light source
  5. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    A little help is needed here.
    The resistor is calculated using the following
    Vs-Vl/Il
    Vs = Volts supply (eather 5v or 12v)
    Vl = Volt load (led's 2.2v)
    Il led's current(100mamps or 0.1 amps).
    so
    12-2.2/0.1
  6. scq
    4 Mar 2005
    Therefore...
    +12v
    Gnd
    Gnd-------------------------------------|
    +5v -----------(resistor)--------------- LED
    Is that setup right? What resistor should I use?
  7. bender386
    bender386 What's a Dremel?
    5 Jan 2006
    is it realy 100ma that seems like a lot for a led but if it is then you will need a 33ohm resistor.
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The maths gives 28R, there's a 30R commonly available which is a bit nearer on a 5V supply. 33R will give the LED 85mA, a 30R 93mA. Use a 0.5W or more.
    Or for the full 100mA, use two 56R in parallel.
  9. bender386
    5 Jan 2006
  10. scq
    4 Mar 2005
    A little diagram or schematic would be major help, thanks!
  11. cpemma
    cpemma Ecky thump
    27 Nov 2001
  12. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    that is the diagram correctly made.
    Ohm's law. Good for led users.
  13. MrMacomouto
    MrMacomouto What's a Dremel?
    28 Mar 2004
    You will need a 510 OHM resistor, if you take the power from a 12V wire.
    (brown, black, black, brown, green I think)
  14. scq
    4 Mar 2005
    Thanks!
    But what if I take it from the 5v?
  15. bender386
    5 Jan 2006
    what you do is
    V(supply)-V(led)=current X resistance
    so
    5 - 2.2 = .1 x R
    so
    2.8/.1=28ohms
  16. AJB2K3
    12 Dec 2005
    Perhaps now is the time to mention that thats a 5 band risistor and that there are also 4 band risistors
    Erm where did you find that? that will realy confuse him when what i posted is the standered formuler and what you posted is just damn strange :confused: :confused: :confused:
    NOTE ON BLUE LEDS
    I tend to use 12v lines for case lighting (i have loads of leds for cars) but when im modiyfing front pannels i use 5V which means you realy need to pay attention when buying leds.
  17. bender386
    5 Jan 2006
    thats just ohms law with the led bit on it.
    V=IR
  18. AJB2K3
    12 Dec 2005
    No ohms law is r=v/i
    not vs-vl=i/r
  19. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Maths for dummies
    If V/I = R
    Then V = IR
    And I = V/R
    It's no good parroting a formula if you don't know how it works. :nono:
  20. AJB2K3
    12 Dec 2005
    I know ohms law and the corrected version for led (im a sparky after all) its just the way he wrote it looked very confusing. is it some sort of american way of doing it because i was always thaught the versions i know not the odd backwards version.
    vs-vl=i/r its wrong anyway because V=I X R
    Given that then V=0.00357, erm thats a little different to V=2.8
    even a 5 yeay old can spot that !
