Electronics molex voltage wires - help with leds :)
Discussion in 'Modding' started by retrogamer, 30 Sep 2004.
  1. retrogamer
    retrogamer What's a Dremel?
    23 Aug 2004
    can anyone please tell me which of the wires on the molex are what voltage??? ive heard there are 12v (obviously) but also 7v and 5v but dont have a clue about wiring up leds in parralell :S ive got 8 green leds that take i think around 3v at 20mA so what could i do to run em at? i also have 56 ohm reistors and 68 ohm if its any help :)
    thanks very much :D
  2. Ben '71 1200
    Ben '71 1200 What's a Dremel?
    16 Aug 2004
    http://www.bit-tech.net/article/68/ the bit-tech LED calculator
    Yellow is 12V
    Black is 0V (ground)
    red is 5V
    to 7 Volt it you'd need to use the 5V wire as the ground with the 12V wire as the positive line.
  3. SteveyG
    SteveyG Electromodder
    23 Nov 2002
