Modding Molex Wiring
Discussion in 'Modding' started by antoniohawk, 21 Mar 2005.
  1. antoniohawk
    antoniohawk What's a Dremel?
    21 Oct 2004
    I have a 90 degree molex connector that I just rewired, but I'm not sure that I did it right and I don't wanna blow the hard drive or something.
    Code:
      _________________
     /  [COLOR=DarkRed]o[/COLOR]   o   o   [COLOR=Yellow]o[/COLOR]  \
    |___________________|
    Let's say that that is the port on the back of the hard drive. From left to right I have Red, Black, Black, and Yellow. Is that the way that it should be?
  2. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    Yes that seems fine if I've understood you correctly :thumb:
    <A88>
  3. antoniohawk
    21 Oct 2004
    Any risk of something being damaged if we're both wrong? :)
  4. <A88>
    10 Jan 2004
    Yes :p Okay, hold the molex and look at it from above, connecter facing away from you, the correct way up. It should go... red-black-black-yellow.
    I'm pretty sure I understood what you said first though so it should be fine.
    <A88>
  5. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Reverse the yellow and red on that picture :)
  6. <A88>
    10 Jan 2004
  7. coorz
    coorz Miffed
    25 Apr 2003
    Simply compare it to another un-touched molex connector. The housings are polarised so there can't be much room for mistakes.
  8. Leeum
    16 Feb 2004
    Going off your first picture that'll kill the HDD, the yellow and red need swapped :blah:
  9. antoniohawk
    21 Oct 2004
    Compared to the picture that alexwilks88 posted, my molex connector looks like that. So if the picture is right, then I should be in the clear.
  10. tater salad
    tater salad What's a Dremel?
    26 Nov 2004
    just looked at my molexes, with the chopped off corners facing up, looking at it while it is plugged in it should be red,black,black,yellow, which is what he has.
  11. pr0xZen
    pr0xZen What's a Dremel?
    5 Nov 2004
    Male plug. "cut edges" facing upwards, plug facing towards you.
    Female plug (this is a "fan molex split", but you could see it as the molex connector on the HD. "cut edges" facing upwards, plug facing towards you.
  12. antoniohawk
    21 Oct 2004
    Thanks pr0xZen, that's what mine looks like. :)
  13. ehrnam45
    ehrnam45 What's a Dremel?
    5 Jul 2004
    or as a last ditch, you can always look at the PCB of the drive below the connector, or check the technical specs in the manual :p
