Electronics momentary key switch?
Discussion in 'Modding' started by dukebox_1st, 26 Apr 2002.
  1. dukebox_1st
    dukebox_1st What's a Dremel?
    26 Apr 2002
  2. viridius
    viridius What's a Dremel?
    7 Apr 2002
    I'd recommend the SPST switches. None are momentary, but you'll have to turn the switch on and then off for it to work.
  3. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    Most automobile ignition key thingies are momentary. one to turn on and further to start. you could use one of them and just connect the start circuit, or if you had a pelt or somthing you could hook that up to the on circuit and it could precool for you.
    If you dont get what I mean than tell me, but you could probably get a key ignition thingy from a junkyar with a key for cheap...
