Electronics Momentary switch fanbus?
Discussion in 'Modding' started by FA-MAS, 28 Feb 2003.
  1. FA-MAS
    FA-MAS What's a Dremel?
    28 Feb 2003
    I don't know if I should post this in the "What do YOU want?" thread or just make a new one. So I made a new one. I've also posted this on the [H], I haven't gotten any help yet. This looks like the place.
    I need some help desiging a circuit. Here's basically what I'm trying to do. I'm trying to create an off/7v/12v fanbus with dual color leds using momentary switches.
    Basically I wanna have 3 states. I would like to be able to move through them by pressing and releasing the momentary switch. Those states are off with no led, 7v with led color 1, and 12v with led color 2.
    I know it's gonna include resistors for the leds. But, I have no idea on what else it should contain.
  2. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
  3. FA-MAS
    28 Feb 2003
    I skimmed over that thread, I must have skipped right over a couple of the circuits.
    Would you send me the imags for:
    The 4017B IC 12V/7V/OFF UltraBus (Single PTM button operation) with LED indicators
    Or i could just wait till you get them fixed.
    That one might be what I'm looking for, I'd like to check it out. Oh, another thing is that I can't read electronic schematics. So at one point, I'm gonna need help translating.
    Thanks.
  4. acrimonious
    8 Nov 2002
    No problem
  5. acrimonious
    8 Nov 2002
    I've just fixed that circuit for ya
    any comments, feedback, or help with the diagram stick in that thread
  6. FA-MAS
    28 Feb 2003
    Ok, thanks.
