money no object
Discussion in 'General' started by merlin 65, 19 May 2006.
  1. merlin 65
    merlin 65 What's a Dremel?
    13 May 2006
    i was laughing the other day when my wife said your going to have to take a mortgage out for this new computer and it got me to thinking , lets say you didnt have to worry about that up and coming mortgage payment and you could buy your dream pc what would you buy what would the system you always dreamed of consist of
  2. mushky
    mushky gimme snails
    24 Mar 2003
    Not much to be honest. I'd be happy with a reasonable gaming system with a seperate fileserver with loads of RAID goodness. Nice big screen and decent audio.
  3. Tibby
    Tibby Back Once Again
    9 Oct 2005
    A HD projector is top of my list.
    Then the most up-to-date parts based on the current hot streaks.
    Can't really say more than that.
  4. Guest-2867
    Guest-2867 Guest
    Dual Everything, Nice Big 30" Widescreen LCD, All The Trimmings hardware wise, best peripherals and a 'proper' 7.1 Theater setup (AV reciever, big floorstanders, quality sub)
    Apart from that i'd probably buy a nice glass desk for it :)
  5. LAGMonkey
    LAGMonkey Group 7 error
    4 Aug 2004
    a MAH-OOOOOOOO-sive storage PC, a system for gaming (read 'top o-line') and a nice and quiet HTPC. Of course all with silly large HD screens and audio. That 3 monitor desktop idea appeals to me :p
  6. specofdust
    specofdust Banned
    26 Feb 2005
    A holiday around the world and a £500 machine. Then I'd clock the crap out of it.
    Part of the whole experience is buying cheaper bits that are gonna clock like crazy.
  7. LAGMonkey
    4 Aug 2004
    Or buying expencive kit and seeing how much you can push it :p
    I do like the holiday idea tho :)
  8. merlin 65
    13 May 2006
    3 monitors are ok but mine will look even better if i can get this lift sytem working cos 3 screens rising out of the desk will look even cooler
  9. dom_
    dom_ --->
    4 Jan 2004
    well you could spend upwards of £50k on just a decent projector, then £400-500k on a decent surround system to go with.
    Then start on the pc :D
  10. Guest-2867
    Guest-2867 Guest
    I can understand the surround system, but what projectors are available for £50k??? :jawdrop:
  11. fev
    fev Industry Fallout
    13 Aug 2003
    sony have a very nice projector worth 44k second hand
  12. P2D
    P2D 99.999% Pure Spam!
    26 Mar 2004
    surely you're talking cinema spec stuff for 50k??
  13. fev
    13 Aug 2003
    no it was for the home/school/office
  14. Mister_Tad
    27 Dec 2002
    Runco and Faroujda (sp?) make some top spec projectors that run in to 6 figures, though I'd probably still pick the Sony Qualia Projector, as its phenomenal for the price (~$25k)
    Wouldn't change much on my system given a limitless budget, probably just replace the drives in my array with 8x 150GB raptors for a giggle. Would really splash out on a gen3 LTO drive and a few carts though (~3k or around there)
    Would be tempted to replace my main screen with a 24" and throw in SLI 7900s to actually play games in its native res, but I hardly play games anyway.
    Wouldnt change much on the hi-fi either tbh, probably just pick up a consonance droplet CD player. Would go a little bit silly on a home cinema setup though, probably ~£70k /drool
  15. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    I would go for that new intel motherboard. Looks good. Smack it full off the nicest RAM out there. Load it up with a RAID 5 15,000 rpm hard drive array. x1900xt Crossfire. Nicest conroe when it comes out. Plenty of heat pipes, just, everywhere. Then you just grab the nicest monitor you can find.
  16. fev
    13 Aug 2003
    "nicest" ain't technical, get more involved!
  17. Solidus
    Solidus Superhuman
    26 Dec 2005
    Im building my dream pc.
    Well its not exactly the "best" but it will be top of the line in most parts, definately enough to play all the games.
  18. Lucy2005
    Lucy2005 What's a Dremel?
    25 Jun 2004
    well my dream pc would be as follows, but id get an experianced person to put it all together for me because i am no good at that lol
    Case Silverstone "TEMJIN" TJ07S (Silver)
    Motherboard DFI Lanparty NF4 SLI-DR Expert nForce4 SLI PCIe Skt939
    CPU AMD Athlon FX60
    Memory OCZ® Gold Series Gamer Extreme 2GB DDR PC4000 *2
    HDD Seagate 750GB 7200RMP SATAII *2
    GFX card XFX 7900GTX XXX PCI-E 512MB DDR3 DUAL DVI *2
    PSU 580W Tagan 2Force T580-U22 SLi U-Quiet 21db
    Monitor Samsung 244T
    Keyboard Saitek Eclipse Keyboard PZ-30AX
    Mouse Logitech G5 Laser Mouse USB
    Sound Creative Sound Blaster X-Fi Platinum
    DVD Drive Plextor PX-755SA SATA Black
    Cooling Danger Den TDX Athlon64 Block 1/2"
    Danger Den 1/2" Maze4 DFI Expert
    Danger Den NV - 7800 Sli Water Block
    Danger Den 1/2" ID ClearFlex Hose 1.59
    Alphacool Laing DDC- 1 Plus 12volt Pump
    Black Ice Extreme III Radiator (1/2" Hi-Flow Fittings)
    Cape Bullseye Blue Anodised reservoir
    Bullseye bay mount
    120x120x25 Papst Case Fan x7
    Extras Alphacool LCD-Display 240x128 Pixel Blue
    i think thats everything, comes to around 4 grand :jawdrop: so i dont think i could afford it anytime soon :waah:
  19. Mister_Tad
    27 Dec 2002
    Given a limitless budget you'd get a tagan PSU?
    If you can only make it to 4 grand, you need a bigger imagination :p
    Tyan NF-Pro dual 940 board
    2x opteron 280
    4x 1GB ecc reg'd
    2x 7900GTX
    Areca 1280
    12x 150GB raptor
    hotswap bays for the above
    couple 24" screens
    emu 1820
    LTO2/3 backup
    physx
    1/2" water on gfx and cpus
    10mm water on the NB, physx and areca
    a case that will fit it all
    getting into 5 digits there :thumb:
  20. NoahFuLing
    NoahFuLing What's a Dremel?
    18 Jun 2005
    Only five digits? That doesn't show much imagination. :naughty: Here's a short list compiled in a short amount of time.
    Thunder K8QE w/M4881 Processor Expansion board
    8x Opteron 885
    2x Nvidia 7900GTX 512MB in SLi
    128 GB of 4GB ECC Registered PC3200 RAM, CAS2 (it exists, I believe)
    Areca 1260
    16x 150GB raptor
    Hotswap bays for the above
    Four 30" LCD's
    LTO2/3 backup (possibly better)
    Emu 1820
    ASuS physx card (shares PCI with Emu via splitter)
    Custom phase on all CPUs
    Chiller-powered water cooled GPUs
    10mm water on the NBs, physx, VRMs, and areca
    A case that will fit it all
    And that's just the central machine. We aren't talking about the offsite NAS, nor the clone of this computer running the 360degree simulator in your office. :naughty:
