Displays Monitor arrived with European power cable
Discussion in 'Tech Support' started by Zehetmayr, 26 Sep 2016.
  1. Zehetmayr
    Zehetmayr Member
    23 Apr 2011
  2. CrapBag
    CrapBag Well-Known Member
    17 Jul 2008
    Its just a standard kettle lead any will do.
    Could always cut the euro off and wire a uk plug but easier to buy a lead if you dont have one.
  3. Zehetmayr
    Zehetmayr Member
    23 Apr 2011
    OK great. When you say any, do you mean any? I don't need to be careful of voltages etc?
  4. CrapBag
    17 Jul 2008
    Europeans use the same voltage as us as far as i know but anway its just a lead there's nothing active in it so voltage isnt an issue.
    If it was a US spec monitor then things would be different.
    I have cable with an adaptor in the middle and you can switch between a euro and a uk.
    If you have a uk psu lead knocking around that will do fine.
  5. Zehetmayr
    Zehetmayr Member
    23 Apr 2011
    Superb - many thanks CrapBag. Much appreciated.
  6. modd1uk
    modd1uk Well-Known Member
    4 Sep 2006
    Double check its not got a massive fuse in whatever cable you replace it with :)
  7. theshadow2001
    3 May 2012
    I've bought stuff like this from Germany. Just snip the plug off and wire your own one on.
    It's no harm to pull the fuse out of the plug that it came with and put it into the one you wire on yourself.
