A/V Monitor Choice + help - Connecting games console
Discussion in 'Hardware' started by OldY, 22 Mar 2006.
  1. OldY
    OldY What's a Dremel?
    10 Mar 2006
    I was in Gitem (Technology Store) and they had just got in Fujistu 19inch widescreen monitior - Max Res 1440x900 (if i remember correctly) and has a vga connection. Price 299euros about £235? It looked good quality when they turned it on.
    Do you think its worth it?
    Also how would I connect a playstation 2 to it? Because i have heard that you can do this with a vga connection on the monitor. :cooldude:
  2. OldY
    10 Mar 2006
    Would it be the same with an Xbox 360 as I am thinking of purchasing one?
  3. mushky
    mushky gimme snails
    24 Mar 2003
    Xbox 360 will easily connect to it with the right lead. PS2 is not so easy. The games need to support progressive scan, which not all of them do. You could spend a lot of money on a converter but they are expensive.
