My PC display has died last night. I was panicking it was my gpu . 2560x1440 @ 75mhz. What are my options as about £150 budget. Gpu is 980ti.
Do you own a soldering iron? Chances are a handful of capacitors are blown or bulging. Could be a fairly simple fix, if you're the handy sort.
+1 to what @David says, It's a pretty easy job if you have a steady hand. https://forums.bit-tech.net/index.php?threads/replacing-bad-caps.196542/#post-2456892
