Graphics Monitor fading in and out
Discussion in 'Hardware' started by Melov, 4 Mar 2004.
  1. Melov
    Melov What's a Dremel?
    30 Apr 2003
    It's not a huge problem, but it is quite annoying when you can notice it. And I can notice it. -.- So basically my monitor will go from normal to a darker tint then go back to normal. It's not a drastic change but it's weird. It only happens when I'm in a area with alot of black. I've tried degauss and changing frefresh rate but nothing seems to work...any suggestions?
  2. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    how often does it do it? is it random, or only when there is a lot of black on the screen?
  3. Melov
    30 Apr 2003
    It mainly does it while I'm on my desktop, which you can see here. I noticed it doesn't start to do it after I first boot up. It takes a few hours before it starts to do it. Restarting doesn't fix it. And it doesn't do it constintly. It only does it for a few seconds, stops, then does it again later. It's completely random, I'd say. It also does it in a 2D game I play called Infantry. I only noticed it in there because it is a slow paced game compaired to all my FPS. I havent really noticed it on them, but it probably does do it in them. I'm almost sure it's not a video card problem. My monitor has always done this come to think of it. And the card has been replaced 2 times due to bad ram (my luck!).
  4. Xen0phobiak
    8 Aug 2002
    sounds like a component that doesn like heating up tbh. Cant really help you sorry.
