Other Monitor feels too bright,any recommendation to reduce eye strain?
Discussion in 'General' started by isaac12345, 31 Oct 2013.
  1. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    Hi all!
    For the past few months, I have been suffering from a problem where I feel that my monitor is a bit too bright, especially when I am reading/writing on a white background such as this. I recently got an eye test done from specsavers with the following results -
    Right eye - SPH - +0.50
    CYL - -0.50
    Axis - 85.0
    Left eye - SPH - +0.50
    CYL - -0.50
    Axis - 75.0
    BVD - 12.00
    They recommended glasses along with an anti-glare coating. I haven't got them yet but I was wondering how could I further reduce eye strain from my monitor as it seriously affecting my productivity as I read and write a lot on my computer. I blink a lot and cannot look at the screen for too long.
    The following are the settings on my monitor. It is a Hanns-G HL-231 connected to a MSI 8800gt through a VGA port-
    Resolution - 1920 x 1080(native)
    Refresh Rate - 60Hz
    Colour Dept - 32bit
    Brightness/Contrast -
    Brightness - 32
    Contrast - 57
    X-contrast - Off
    Preset Mode - PC
    Colour Setting - Nature
    Image setting -
    Aspect Ratio - Full
    H-Position - 50
    V-Position - 50
    Clock - 50
    Phase - 86
    Sharpness - 0
    All colour settings in the Nvidia Control Panel are all set to 'application control' apart from the following enhancements, which are at default -
    Digital Vibrance - 50%
    Hue -0 degrees
    My room has 2 windows, one right above me, on the ceiling and one at the back wall to the right and behind the monitor. It doesnt help that much if I cover them or not, the monitor still feels too bright.
    I hope this information is useful and will help you to help me.
    Thanks! :)
  2. Pieface
    Pieface Modder
    8 Mar 2009
    Turn the brightness down?
  3. GeorgeStorm
    16 Dec 2008
    As Pieface said, have you tried turning the brightness down? Seems the most obvious solution.
  4. Krikkit
    21 Jan 2003
    Turn the brightness down to match its surroundings. Set it an arms length away from your normal reading position, with your eyes level with the top edge.
    Take frequent breaks, make sure you blink often (rather than staring), and try some eye exercises. Once every few minutes have a stare out the window at a distant object, try and keep it in focus for 30s.
  5. isaac12345
    20 Jul 2008
    I have turned it down to 11, hopefully this will help over the long run.
  6. isaac12345
    20 Jul 2008
    By the way the lights at the moment are off in my room. Will that affect me a lot?
  7. faugusztin
    11 Aug 2008
    Yes, you should not be in dark (unless you got 3 monitors like me, which is nearly the same thing as having secondary light source in the room :D ). And sometimes lowering the brightness makes things worse, because of the PWM brightness regulation on cheaper LED-backlit LCD monitors.
  8. isaac12345
    20 Jul 2008
    Still not helpful. I have a dull ache where my eyebrows are.
  9. tuk
    tuk Don't Tase Me, Bro!
    28 Oct 2012
    Pliqu3011 likes this.
  10. isaac12345
    20 Jul 2008
    Looks very interesting! Will give it a go. Thanks!
  11. tuk
    28 Oct 2012
    Make sure you set your location so that it works properly ...the app automatically sets the screen depending on the location of the Sun in the sky at given times, the only time I disable is for gaming and movies.
  12. biojellywobbles
    biojellywobbles Minimodder
    12 Feb 2011
    I use flux like tuk suggested, works great and has a handy switch to deactivate for an hour if you need to do some design work where colours matter.
  13. julianmartin
    julianmartin resident cyborg.
    25 Jul 2004
    that is WHACK! I am loving it though, great suggestion!
  14. tuk
    28 Oct 2012
    When you've been using for a few days, wait till late in the evening then disable Flux and feel your eyes physically cringe as your screen slowly goes back to normal.
  15. RedFlames
    23 Apr 2009
    Flux, while a good idea, really does my head in [moreso than having my monitor at 'full brightness']...
    That said as soon as I got my current monitor I had to turn the brightness way down... on full/default it was so bright you could probably see it from space...
  16. Krikkit
    21 Jan 2003
    It's not a magic potion, Harry Potter won't swoop down and wave his wand with a cry of "Oculus unpussyus!" and make it all better. Put some effort in.
  17. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    There's your problem. You're supposed to go up to 11, not down!
  18. RinSewand
    RinSewand What's a Dremel?
    11 Sep 2006
    Personally I get the same thing after long periods unless I light the wall behind my monitors. I've got an LED strip hung off the back of them, and this is aimed at the wall. I tend to strain my eyes if they're adjusting for light from the monitor, but the surround is dark. Works well in conjunction with software! I have to say, since I've done this I can leave my room light off without issue.
  19. julianmartin
    25 Jul 2004
    What is bad about it in your opinion?
    I am finding my cursor is now blue, which is slightly odd....
  20. KidMod-Southpaw
    28 Sep 2010
    Flux sounds pretty darn cool- I'll have to give that a go when I'm home.
