Displays monitor for 720p/1080p viewing
Discussion in 'Hardware' started by agentsmith, 14 Dec 2008.
  1. agentsmith
    agentsmith What's a Dremel?
    14 Dec 2008
    so i recently started getting alot of 720p/1080p videos. right now i have a 17" lcd monitor, and am considering getting a 21.5"/1920x1080 monitor (http://www.newegg.com/Product/Product.aspx?Item=N82E16824236051&Tpk=VH226H). now, i just want the best picture i can get (for around $200). i've heard that a smaller monitor is sometimes better, so i'm not really sure and am somewhat skeptical of getting a new monitor, because the main reason i want one is for the video watching (720p more so than 1080p). i also do some internet browsing and watch xvid releases too, and some pretty light gaming.
    thoughts/suggestions?
  2. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    dell's new 24" 1080p monitor looks pretty damn nice. it's a little above your budget, but at 21.5" you aren't going to notice much of a difference between 720p and scene xvid unless you are <30" from the screen.
  3. agentsmith
    14 Dec 2008
    yea, these are for watching right at my computer desk, so im no more than 12 inches away id say.
  4. julianmartin
    julianmartin resident cyborg.
    25 Jul 2004
    you sit a foot away from your monitor? that must hurt....
    and my housemate has the new Dell monitor, it's pretty swish I must admit.
  5. Krikkit
    21 Jan 2003
    Definitely get a 24"er tbh. Much more fun. :D
  6. agentsmith
    14 Dec 2008
  7. Slaughter
    Slaughter What's a Dremel?
    1 Aug 2007
    I say go Nec, Dell 2408 has majure problems and HP has low quality electronics and processor. I am probably buying NEC 2470
  8. shaile
    shaile Go BIG or GO HOME
    21 Nov 2008
    What are these major problems? I am also considering the Dell and from what I have read, it is rock solid. Cnet.com rated it as a 4/5 star and an Editor's Choice.
  9. notatoad
    25 Jun 2004
    the dell is perfectly fine for most uses. the NEC is a professional grade monitor, it will have a slightly more accurate color palette and stuff, but unless you are using it for professional graphic design work or something like that, the dell will be more than adequate.
