HERE IT IS!!!!!!!!!! Cutting the plastic on the back of the monitor Cut out Sparks a'flyin Window put in (didnt care that tape was showing cause it is in back) The look as u walk in my room The greatest Monitor mod....looks even better in person gives off tremedous glow look thro the window at my wireing job for the fan i threaded the wires from the fan out the back grill...and pluged them into a 6 volt battery this is the hot wired PSU powering the light it is accually a CLEAR fan and the light gives it a beatutiful glow LIGHT ON *CLAP CLAP* LIGHT OFF TOTAL COST $30 TOTAL TIME 45 min FEED BACK
Holy crap thats bright! You did more than you are showing here, what about the fan in the side and the light source and how its powered?
Nice i like it. I wanted to do that with my Monitor but at the Moment i dont no Electrics how to Hook up Lights & Fans. someday i will Learn Good Job
can you just get some power from the monitor itself? i mean, just knowing where is some current flowing and measuring it, placing some resistors and you got the power needed to turn on your light and fan.. is this logic or is it just stupid?
wow, that is very bright, and i would not try testing anything in the monitor, they have like 10kv running throught them, i would just get external power it would be much safer
ok heres the scooop (ill get pics when i get home from school) the light is running off a "test" psu (w/o a mobo connected)..... the fan i bought came with bare wires and thats it......so i took some handy dandy speaker wire and extended the wires thro the back grill of the monitor and as some of us know a molex connector runs at the wrong voltage to power a fan thats y most have resistors built in and/or a molex pass thro.....so i am running off a 6 volt battery....... THE MAIN THING TO KEEP SAFE IN THIS PROJECT......pay attention to where things will go when u put the case back on cause if it is touching nething ne the monitor u could get seriuosly hurt or die
its not scary to take apart a monitor the interals are kinda heavy though, and its akward to move them ive painted 2, and they turned out really nice
Gonna have to move this one across to Modding - The Project Logs forum is for just that - project logs. As this is a finished mod, it'll have to go in Modding. *n
1) the heat now can't escape from the top? but, 2) the emi/rfi/whatever can? yeah, it looks pretty, but it seems a bit foolish
