Displays Monitor recommendations and latest
Discussion in 'Hardware' started by MiNiMaL_FuSS, 9 Feb 2020.
  1. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    Hi all,
    My trusty Dell 2407wfp just died.
    I loved that monitor and it had a decent 8bit PVA panel in it.
    So it's time to buy a new monitor, I'm not a big gamer and don't really need anything much bigger 24" although I wouldn't say no to going up to around 28/30"
    I'm totally out of date on kit!
    Are TN panels still to be avoided or has the technology caught up?
    What can I get for £100? Or should I be going second hand?
    Appreciate your thoughts!
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
  3. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    RIP your 2407 :( Awesome, awesome monitors.
    Are you wedded to a particular resolution? I think I'd really struggle to drop down from 1200p to 1080p (even though it seems like a minor change, it'd bother me no end). You can get a Dell U2412M from Amazon for just over £150 if you're looking for a like-for-like replacement, although it's over your £100 budget.
    If I was going above 24" then I'd probably not do so at 1080p - I reckon 1440p at 27" is roughly equivalent to 1080p at 24", but that might be budget-busting too.
    And I'd probably avoid TN panels too, as they tend to be a bit grim (and will almost certainly be inferior to your old monitor).
  4. MiNiMaL_FuSS
    24 Dec 2003
    Think I'll need to stick with 1920 x 1200
    I don't mind 60hz, I've only ever had 60hz, so I don't know any difference.
    If it makes a sizeable difference in happy to chuck around £150 at it.
  5. MiNiMaL_FuSS
    24 Dec 2003
  6. MiNiMaL_FuSS
    24 Dec 2003
  7. bawjaws
    bawjaws Multimodder
    5 Dec 2010
  8. MiNiMaL_FuSS
    24 Dec 2003
  9. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    That looks decent.
  10. Anfield
    Anfield Multimodder
    15 Jan 2010
    The Samsung one is a 29" Ultrawide, which is basically equivalent to a 24" 1080p with extra screen space on the sides.
    As for that £80 27" Dell, I'd give that a go:thumb:
  11. MiNiMaL_FuSS
    24 Dec 2003
    Thanks chaps.
    I've emailed the Dell.
    May consider the Samsung as a stop gap (can always sell it on again) if I don't hear back from the Dell by the end of the day.
  12. SuperHans123
    SuperHans123 Minimodder
    27 Dec 2013
  13. wyx087
    15 Aug 2007
  14. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    That one is the MVA panel, I bought the IPS panel - the model number has a "D" suffix denoting the difference. The IPS version is a great monitor, I am loving mine - it's a lot of screen real estate.
    Link to IPS version (only £13 more): https://www.cclonline.com/product/a...ps-panel-amd-freesync-75hz-silver-q3279vwfd8/
  15. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    I've got one of those, great monitor, loads of space compared to 1080. IPS for only £13 sounds like a bargain.
  16. SuperHans123
    27 Dec 2013
    This is the monitor I have had for the last 6 months.
    Great screen for the price.
  17. MiNiMaL_FuSS
    24 Dec 2003
    Thanks all.
    Just setup the Dell 2711 a few minutes ago.
    Got it for £60 in the end as it's got a bit of backlight bleed along one edge, bargain by all accounts.
    I've never seen a backlight bleed like this one though, it's basically a thing vertical line (1mm wide) right on leftmost edge of the screen, it's hard to spot on anything but a pure black background so I think I can just forget it's even there. I would have said it was a stuck line of pixels, except it's not bright and not a colour, just a little faded or overbright line.
    Loving life at 2560 x 1440!
    wyx087, bawjaws, adidan and 1 other person like this.
  18. Anfield
    Anfield Multimodder
    15 Jan 2010
    £60? That's a steal:thumb:
