What is the name of the wire that goes from the Monitor to your PC for the speakers? LMAO My mind is completely blank on this You know the thin wire usually with a green color at the tips plugs in to the green colored input on the back plate of the PC. I need one of these as it is a pretty old monitor with limited connections for audio.
3.5 mm interconnect cable if searching audio cable stores, active speakers often use them and for recording off the headphone out of portable devices. The so called analog hole according to record companies.
