Displays Monitor upgrade - Advice/opinions wanted
Discussion in 'Hardware' started by Plugs, 10 Jun 2010.
  1. Plugs
    Plugs Minimodder
    5 Nov 2009
    Hi
    I currently have a 17" 4:3 monitor which I am thinking of upgrading to a widescreen 16:9.
    I dont want to lose any physical vertical height, so my trigonometry tells me I need a 16:9 screen that is at least 20.8" corner to corner.
    1920x1080
    It needs to have HDMI (for a console), DVI (for the PC).
    Budget: £150
    It doesnt need to be amazing, just the best quality for the budget (as well as fitting the above criteria)
    I saw this on amazon http://www.amazon.co.uk/Samsung-B23...?ie=UTF8&s=electronics&qid=1276125580&sr=1-17
    but i was hoping someone might have more insight and/or options as i know little on the topic.
    Thanks
  2. Plugs
    Plugs Minimodder
    5 Nov 2009
  3. mrhrk01
    mrhrk01 What's a Dremel?
    20 May 2010
    I just bought a ViewSonic VX2260WM for a cousin of mine , it may also fit the bill for you. Link below:
    http://www.scan.co.uk/Products/22-V...DVI-VGA-1920x1080-300cd-m-200001(DCR)-Speaker
    I was going to test it the Monitor before passing it onto my cousin, but have not yet had the time to test it. However the Monitor has received a good review from Bit-tech:
    http://www.bit-tech.net/hardware/monitors/2009/01/05/viewsonic-vx2260wm-22in-full-hd-monitor/1
    Its a 22 Inch Monitor, wide screen, has the resolution your looking for and is just £2 over your budget.
    I have not come across the Monitor you have linked to in your original post, so I can not comment on that, but I am sure someone will come along and let you know if that Monitor is any good or not.
  4. Plugs
    Plugs Minimodder
    5 Nov 2009
    thanks mrhrk
    the monitor you suggested is also under budget on amazon by £2 (free shipping too for me)
    also more investigating shows that most (if not all) of these monitors are actually 21.5", including the ' 23" ' samsung... so any comments ive made with regards to size dont sit - but 21.5" is big enough anyway
    anyone have any knowledge/experience of an LED backlight then?
    otherwise its a toss up between the viewsonic and the samsung... or the LG... or the other LG :sigh: :rolleyes:
  5. mrhrk01
    20 May 2010
    No worries, if my suggestion was useful then great.
    I would suggest trying to find reviews about those Monitors on Bit-tech or other forums/reviews sites.
  6. Plugs
    Plugs Minimodder
    5 Nov 2009
    Well reviews of the Samsung were hard to come by, so I guess I will rule it out.
    The LED was equally hard to find reviews on - if anyone has compared an LCD to LED LCD, please respond
    The LG (not LED) and ViewSonic come out about equal, with one reviewer worried about colours on the viewsonic, and another worried that the LG is being made from a lower quality screen since they reviewed it.
    On top of that the 23" version of the LG sits at £153 on amazon, is bigger and has a better response time.
  7. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    in the quality range you're looking at, LED or not does not really make a difference in image quality. the only real world difference you'll experience is a smaller power bill, but not by that much.
    also, reponse times. dont stare blind on it. as long as it is under 15ms it's ok for anyone but the fastest videomakers and 1337'est gamers. and there are a few ways of calculating them (black-to-white, color-to-color, grey-to-grey,...) so don't get fooled.
    and i have no clue about any of the screens you found. i'm sorry.
  8. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    All LED should change in theory is limit the amount of backlight bleed-through, so blacks will seem blacker. Apart from that they'll be just the same as any TN pannel.
  9. Plugs
    Plugs Minimodder
    5 Nov 2009
    Ah, thanks for shedding light on the LED (puns are awesome)
    I guess that puts the 23" LG into the lead.
    I'll place an order next week.
    Thanks for your input if you replied
