Monitor Won't Turn Back On After A While?
Discussion in 'Tech Support' started by Tibby, 27 May 2008.
  1. Tibby
    Tibby Back Once Again
    9 Oct 2005
    Hey guys,
    Bit of a strange problem here.
    I have just had to re-install windows due to a hard drive failing on me, and I have come to a weird problem.
    My main monitor will decide to not pick up the signal from my pc after being in power save mode for long periods of time.
    I have to restart the PC and physically unplug, and plug in the cable.
    I am running a fresh install of MCE, using a 7900GS, and using Ultramon for dual monitor setup with my 40" Samsung HDTV as the secondary monitor.
    As you can guess this is quite infuriating, and I wouldn't even know what to google for answers, so I am hoping someone has had a similar problem in the past?
    Cheers for any help guys.
    - Tibby :thumb:
  2. Tibby
    9 Oct 2005
    I'm guessing everyone is as stumped as I am.
    It hasn't happened again yet, but it is still highly irregular.
  3. superseagull
    superseagull If it aint broke, fix it ;-)
    28 May 2008
    what version of mce are you running and is it fully patched?
    i had a similar problem with xp pro where is would fail to boot after several sleep / wake cycles and soon discovered it was a known prob with xp sp2 (not sure if addressed in sp3).
    does your machine fail to fully boot or simply not display the video - if the former focus your attention on microsoft and patch your system to latest or try latest gfx drivers if its the latter.
    good luck
