Graphics ****!!! monitor's too big!!!!
Discussion in 'Hardware' started by vetlel, 14 Jun 2005.
  1. vetlel
    vetlel What's a Dremel?
    7 Apr 2004
    Hi,i am here with a friend with a too big monitor....
    He's wondering if it's possible to have windows maximize programs to a set section of the screen. Just to make sure there is a bit let over on the side for chat and such...
    If not? Can i challenge people here????
    TA Patrick
  2. Hiren
    Hiren mind control Moderator
    15 May 2002
    Why not just set the screen res to a smaller size or get a smaller screen?
    Don't think what your looking is possible not with any software that I know of.
  3. Stompy
    Stompy What's a Dremel?
    16 Aug 2004
    I jsut resize them so they leave the chat window visible and close them like that and they reopen the same size.
  4. Austin
    Austin Minimodder
    16 Jul 2004
    :confused: Windows will still place new windows at a slight off-set though, but if you are mostly concerned with web-browsing then you want something which supports tabbed browsing (where you can easily keep only a single window open). Examples are Firefox, Opera and IE7 when that comes out. It is possible with IE6 either with 3rd party add-ons (or variants) or by using the latest (U.S.) MSN Toolbar.
  5. moddenmania
    moddenmania What's a Dremel?
    18 Sep 2004
    ie come on that browser is full of holes without protection you'll get some terrible spyware on your machine using that get firefox the best browser ever!
  6. vetlel
    7 Apr 2004
    Using Ultramon with an edited script windows can now be resized to the left or right half of the screen (splitting the screen in two virtual monitors). Other windows are not affected though.
    Windows explorer is one of the programs that always pops up with an annoying offset btw.
  7. Darth Joules
    Darth Joules Minimodder
    29 Feb 2004
    How can you have a monitor that's too big?! :eyebrow:
    I've been trying to find a Mitsubishi/NEC Diamond Pro 22" CRT for ages now they've stopped making them. I need big CRT goodness.... :naughty:
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    Which script do you edit?
  9. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    soo true...how can it be tooo big? is that not a contradiction in terms?
    /me reassures the eizo 22" monitor in front that its not too fat! :worried:
  10. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Iiyama still make monitors using the 22" Diamondtron tube, I have one ;) See here.
