Case Mod - In Progress "Monochrome" Lian Li V600f / Finished 28Nov
Discussion in 'Project Logs' started by GotMod?, 26 Jun 2012.
  1. GotMod?
    GotMod? What's a Dremel?
    3 Apr 2012
    Hi to all crazy people!! :rock:
    Some modding from Moscow )
    im new to all these..modding, wc, bit-tech ) first project ever - greetings!!!
    I'll be short for comments, let's get to bizznes, i mean business ) (my english is not too good)
    Here is the case to be modded (Lian Li V600f):
    Not the best solution for a watercooling, but looks freakingly nice!
    The first thing i did was taking it apart:
    *nice stiker on the back:D
    Totally taken apart (sorry for pics quality):​
    Parts to be painted:​
    Some pics of hardware i'm gonna use:​
  2. Sparky1987
    Sparky1987 What's a Dremel?
    9 Jan 2011
    Ah! Always good to see a Lian li build :) I've done a couple myself, the most recent is half done mind you.
    If I could give some advice, always finish your build, even if it costs more then you expected, it's worth it in the end, knowing you built it and it works :).
    Happy building! :)
  3. GotMod?
    3 Apr 2012
    Painted all the parts with matte white:
    And the result:
  4. GotMod?
    3 Apr 2012
    Thank's a lot!!:thumb:
  5. GotMod?
    3 Apr 2012
    Sleeving
    Ok, did the sleeving. Used panda camo paracord.
  6. GotMod?
    3 Apr 2012
    But as i did the sleeving for the first time, i guess i did it not really good.
    I don't like the result. Heatshrink seems to me too ugly )))
    I decided to remake it without using heatshrink.
    Here is the result. Looks much better to me:
    And here is 24-pin:
  7. Shurika
    Shurika Minimodder
    9 Mar 2012
    Welcome to the bit-tech! Your mod is very interesting - looking good so far!
    расскажешь, как делал без термоусадки? у меня тоже репшнур и тоже хочу как у тебя сделать - интересно, как делал. Привет из Москвы:D
  8. GotMod?
    3 Apr 2012
    Thank's Shurika!
    I'll try to make a short vid to show you how to make it shrink-free, its really easy - melt and twist ))
  9. Shurika
    Shurika Minimodder
    9 Mar 2012
    OK, I`ll wait for update
  10. Sparky1987
    9 Jan 2011
    I agree no heat shrink looks lots better :) from your pics so far it's looking good, great finish to your paintwork with clean lines, can't beat a good black and white build :thumb:
  11. Lehani
    Lehani What's a Dremel?
    27 Jun 2012
    Very nice build - yes i would love to see how you sleeve without using heatskrinks :)
    i have some MDPC sleeving for my furture build - so making that without heatskrink would what be lovely :)
  12. GotMod?
    3 Apr 2012
    Thanks!!! :)
  13. GotMod?
    3 Apr 2012
    Time for the inside panels
    Ok, with the help of cardboard, did the templates of the inside panels:
    The AutoCad version:
    And the real ones after lasercut:
    Here is the plan on how to place them:
  14. GotMod?
    3 Apr 2012
    Cut all the holes:
  15. GotMod?
    3 Apr 2012
    Shurika, as i promised, here is a short video on how i make it
    I guess the same method works with MDPC sleeving as well.
    Waynio and Krikkit like this.
  16. GotMod?
    3 Apr 2012
    Just testing how everything fits:
  17. whyte
    whyte What's a Dremel?
    27 Mar 2012
    Cool vid! I'll have to try paracord next time. I just made my first attempt at sleeving and used my fingers to push in the staples... You're right, sliced the **** out of several of em. Looking forward to the rest of this project.
  18. krussellusaf
    krussellusaf What's a Dremel?
    28 Jun 2012
    That sleeving technique is amazing. Thank you very much for the how to vid.
  19. Krikkit
    21 Jan 2003
    What type of paracord did you use? I presume it's the 3mm stuff with the centre pulled out?
  20. GotMod?
    3 Apr 2012
    Thank you all guys!!
    It's usual paracord 550 Type III, approximately 4 mm. There was something in the center, I don't know how to call it, but i had to pull it out.
