Hardware Monsoon Compression Fitting Six Pack Review
Discussion in 'Article Discussion' started by Baz, 20 Jun 2012.
  1. Combatus
    Combatus Bit-tech Modding + hardware reviews Staff Super Moderator
    16 Feb 2009
    Gene at Monsoon just sent me a funky image of all the coloured barbs - I uploaded this and people seem to be able to see but not the other photos. I've re-uploaded the originals to this and the shakmods cable braid article. Let me know if this has made a difference!
  2. MrP
    MrP seeking inspiration
    5 Jul 2007
    12.0 at the mo, but downloading 13.
    new pic works, but others still do not
  3. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    The images are being blocked by AdBlock Plus (and similar ad blockers) because they're 300x250 with 300x250 in the filename - a common ad format. Turn off AdBlock Plus and the images will magically appear.
  4. MrP
    5 Jul 2007
    confirmed
  5. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Or just disable it on that single page from the options menu.
  6. Baz
    Baz I work for Corsair
    13 Jan 2005
    Just thought I'd say, this isn't something we've done purposefully to force ad-block removal. We've used similar images sizes and naming standards for ages. Just seems that the ad-blockers have changed their recognition system.
  7. Combatus
    16 Feb 2009
    Just thought I'd add to what Baz said - I simply used a different ratio in our CMS with an image size we haven't used before to best-fit some of the images. Ad-blockers probably haven't changed, it is in fact my fault!
  8. steveo_mcg
    steveo_mcg New Member
    26 May 2005
    Must be the office firewall, i've still got bit white-listed.
  9. Unicorn
    25 Jul 2006
    Disabling ABP in Firefox on that one page and refreshing the page loaded the images - thanks guys :thumb:
  10. David
    David Take my advice — I’m not using it.
    7 Apr 2009
    You can add an exception filter in adblock for images.bit-tech.net and it'll ignore the the fact that the sizes are stated in the image title.
  11. Unicorn
    25 Jul 2006
    Which is exactly what I've done now :thumb: I have also added exceptions for the non intrusive ads on bit-tech.
  12. hyperion
    hyperion Active Member
    30 Jun 2007
    Sneaky :D
  13. Paradigm Shifter
    10 May 2006
    I'll admit that I've not bought high-end compression fittings - yet - but they've always had the hex keying on the base for a spanner... and I've never needed to tighten beyond 'finger tight' the actual compression head itself. Admittedly I'm pretty good at getting 'finger tight' for me too tight for any friends/colleagues to undo without a mole-grip, however. Not had a leak either.
    These do look pretty nice, though.
  14. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I don't understand why they come in 6's. Most people will use 8 or 10 fttings, so 6 is an annoying number...
  15. Unicorn
    25 Jul 2006
    I wondered at that too. I think 8 would have been a better number per pack (single block loop being pump, res, rad and block) but from a marketing point of view it's a winner because if someone needs 8 fittings, they might or probably will buy two sets of 6.
  16. B3CK
    B3CK New Member
    14 Jun 2004
    I used two packs of these for one of customers. No leaks, easy to put on, but that wrench kills my hands. I was tempted to dip the handle in liquid rubber, but never got to the h/w store. Worked great even on a rad with recessed thread holes. A great buy for tight clearances.
  17. Combatus
    16 Feb 2009
    Good point. If you have a combined pump/res such as one of the fancy after-market tops for the DDC pump then you would only need six assuming a CPU only loop. They're also readily available separately so buying a few more isn't an issue - I guess everyone needs six, but not everyone needs eight or 10 :D Adding another two would push the price above £30 and most likely above $50 too which could have been anther reason but I agree that eight would make more sense.
  18. Yorkie
    Yorkie Active Member
    22 Jun 2010
    Hmm Interesting
  19. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    i like the look of these, so if i get the water cooling bug i might have to get some
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    I like them. :)
