Case Mod - In Progress Monsta Lian li v2000 build.
Discussion in 'Project Logs' started by b1g-d0g, 16 Apr 2009.
  1. The boy 4rm oz
    10 Apr 2008
    I really do love black and white, a perfect contrast. The mod is coming along nicely, nice work.
  2. stonedsurd
    11 Mar 2009
    Amazing work with the black and white! :thumb:
  3. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Will do the sound card but i may lose my warranty on my videocard if i mess around with it.
    The pump will be mounted with rubber standoffs as ive had one of these pumps before:)
  4. WolfandAngel
    WolfandAngel Got fins?
    2 Dec 2008
    Realy nice!simpel but nice!
    Would like to see the sound and graphics cards painted
    + some white leds ??
  5. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    We'll just put the build the same kind of peer pressure we did with SpellZ to force the switch to i7.
    Trust me:
    YOU!
    DON'T!
    STAND!
    A!
    CHANCE!
    :p
  6. stuartwood89
    20 Aug 2008
    Can't you just cover the offending parts of those cards with vinal film? That way you can peel it all off in case of having to RMA them.
  7. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Yeh may have a look into that :)
  8. Mokey Mokey
    Mokey Mokey What's a Dremel?
    9 Mar 2009
    This is too sexy! :blush:
  9. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Still not much going on at the moment as funds are tight:crying: but i will be doing some more spraypainting as ive got a new fan bus and im thinking of giving the monsta a nice few coats of white paint:drool: and im not going for the 140mm fans anymore as they dont have the cfm i will be fitting 6 Scythe Ultra Kaze 120 x 38mm Cooling Fan, 2000RPM in their place.
    So with luck i`ll have some piccys up later today for you all .
  10. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Got me a new Lamptron FC3 Fan Controller
    Dont worry its being painted white .
    Primer for now
    Heatkiller waterblock brackets now white.
    And the DDC Pump bracket.
    And whats this?
    Painted some silver AC Ryan small holed mesh white for the bottom rad cuts,i think they will look better,mesh on the window will be replaced with plexi of some sort.
    Now lets move on to the monsta,black heck no going white,the rad panels where riveted on so i had to drill them out and i found out the holes where tapped to take M4 screws,so i got some countersunk black ones and redrilled the panels to take them,no piccys of me doing this though.
    Rad sanded down with wet & dry.
    All masked up and even recycled a spam letter that the posty had delivered 10 mins ago.
    A few coats of grey primer this i will leave to dry over night and then start to paint white.
    Hope you enjoy :)
  11. The boy 4rm oz
    10 Apr 2008
    That rad looks fantastic without the sides on it, they should sell them like that. I guess you would get air leakage out of the exposed sides so that's why they don't do it.
  12. ringo
    ringo What's a Dremel?
    14 Jun 2008
    It's allways intersting what other people do. I like your Fan-Controll panel.
  13. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    looks fantastic nice work
  14. bagman
    bagman Minimodder
    18 Apr 2009
    like your fan control and the rad looks sick
  15. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Piccys of the rad painted white .
    Had to take the paint off the heatkiller block brackets as they would`nt fit back in .
  16. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    Nice job there mate, always good to take your time while painting stuff like that. As you can clearly see, it was worth it :)
    Good luck with your mod, it's look real good. :thumb:
  17. psy_dreams
    psy_dreams Hardware Arena - TR
    20 Feb 2008
    Very nice paint work
  18. stonedsurd
    11 Mar 2009
    How about anodizing them some other color? or plating?
  19. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    I have now sold it so need to look for another one but i like the idea of anodizing :)
    Here is a quick piccy of how the rad mesh looks now was takin on my bed the quilt makes it look a bit weird but its ok :)
  20. The boy 4rm oz
    10 Apr 2008
    That's a really nice colour you have there. Is it out of a can or spray gun?
