Case Mod - In Progress Monsta Lian li v2000 build.
Discussion in 'Project Logs' started by b1g-d0g, 16 Apr 2009.
  1. The boy 4rm oz
    10 Apr 2008
    That board is insane, I love it and would buy one myself but they cost around $800AUD lol.
  2. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    You have quite a dream build there.
    Keep up the great work.
  3. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    wow! nice board mate...... im truly jealous.
  4. b1g-d0g
    b1g-d0g Well-Known Member
    30 Sep 2001
    Had to sell most of my hardware,so i now need to work hard and save .
    22/05/09
    Wee update a set of bitspower waterblocks have been ordered for the EVGA X58 Classified from Holland today so piccys when they arrive :)
  5. dark4181
    dark4181 Ero-sennin-tebayo
    3 Jan 2008
    Be sure to read the eVGA forums about the quirks of the Classified. You have to give it some TLC to make it work it's hardest for you ;)
    Sweet mod so far, I'll definitely follow this one
  6. stonedsurd
    11 Mar 2009
    Black Freezer? :thumb:
  7. b1g-d0g
    30 Sep 2001
    Ok a few little upadtes on my build.
    I thought i would test my rad to make sure i didnt puncture anything when i replaced the carbon panel rivets with screws and to test my fittings incase they leak and im very happy to say no leaks at all.
    Ive not bothered to braid the rad fans as im not sure if i will be keeping these,i have found some good sharkoon`s that i`ll need to try out.
    New Koolance 3.25 DDC fitted with XSPC res top
    Next things to do is install the bitspower blocks and the heatkiller cpu waterblock.
  8. Sni9er
    Sni9er Ermmmm 42 ???
    16 Apr 2009
    love the tubing colour scheme nice and bold !
  9. Monkey Puzzle
    Monkey Puzzle New Member
    18 Feb 2009
    Looking really good. :thumb:Those Bitspower fittings are lovely. Are you using white or black tubing - seems to have been swapped round?
  10. b1g-d0g
    30 Sep 2001
    Only got the spare black hose on for now as the rads filled with water to test it working with the pump.
  11. DonT-FeaR
    23 Jul 2008
  12. b1g-d0g
    30 Sep 2001
    Waterblocks fitted and leak tested :)
    Just got some bits to tidy it up and sort out my window and jobs done.
    Drain valve fitted.
    Idles around 32 on stock 920 DO settings with 6 low speed 140mm yates.
  13. The boy 4rm oz
    10 Apr 2008
    Nice temps but I have to say that personally I am not happy with the plumbing, something about it just doesn't look right to me IMO. It's the lead going from the CPU block to the NB block, either face the fitting on the NB block towards the CPU block (not towards the PCI slots like you have done) or ditch those fittings and use normal compression fittings, it just looks abnormal. Just my 2 cents.
    Javerh likes this.
  14. retrogamer1990
    retrogamer1990 What does 'Stock' Mean?
    12 Jan 2009
    yeah +1 the plumbing looks wrong :/
  15. b1g-d0g
    30 Sep 2001
    Agreed just my first try so i will be on it asap :)
  16. DonT-FeaR
    23 Jul 2008
    nice temps
  17. [+]EXEcuteER[+]
    [+]EXEcuteER[+] Cracking up the Plex
    13 Aug 2009
    yeah baby. the rad looks cool. that was a good paintjob at all.
  18. SmoothyGennat
    SmoothyGennat New Member
    17 Feb 2008
    Very nice Mod!! Good job..
    :rock:
  19. b1g-d0g
    30 Sep 2001
    Time for a update me thinks :)
    Had a tidy up down below.
    Silver coil working a treat.
    The new Corsair GT`s.
    Found some spare smoked plexi so i cut out a 120mm fan hole.
  20. stonedsurd
    11 Mar 2009
    NOW the tubing looks hawt.
    And damn, that's some sweet RAM.
