Modding Mood "ring" paint???
Discussion in 'Modding' started by fieroloki, 12 Aug 2004.
  1. fieroloki
    fieroloki What's a Dremel?
    3 Jan 2004
  2. kobaj
    kobaj Banned
    4 Jul 2004
    that stuff is cool you plan on painting your case with that or do you have other ideas. what would be cool is if you stuck it on your keyboard and then after tiping you would have a multycolor keyboard or you could see wich keys you press the most
  3. fieroloki
    3 Jan 2004
    If it wasnt expensive (which we ALL know it will be) I want to paint my pc case :)
  4. r3Q
    r3Q Minimodder
    31 Jul 2002
    2 oz. KIT
    $270
    8 oz. KIT
    $690
    Pint KIT
    $1199
    Quart KIT
    $1749
    owch. but you should only need 2oz for a computer... its a clearcoat ("put over a dark basecoat for best results") and then you add your clear laquer or regular clear coat to protect it.
    $270 is quite expensive.. maybe $50 and i would try it =P
    maybe if i was rich... rofl. :thumb: sweet stuff though!
  5. fieroloki
    3 Jan 2004
    WAY to expensive for me to get just for a PC case..... Yeeeesh
  6. alextwo
    alextwo <a href="http://forums.bit-tech.net/showpost.php?p
    29 May 2003
    You could get the adhesive film, it's just $20 per sq foot. :rock:
  7. 486hawk
    486hawk What's a Dremel?
    18 Jul 2003
    That could be a security hazard…:worried: cool idea though.
