Electronics More questions Rheostat
Discussion in 'Modding' started by BURNER-X, 9 Mar 2002.
  1. BURNER-X
    BURNER-X What's a Dremel?
    1 Mar 2002
    I'm really sorry about all the spam I just have a ton of questions I'm trying to learn more about things = ) I need a Rheostat for a delta fan.
    Specifications: 80x80x38mm, -->80.16<-- CFM @ 5700 RPM, 52.5 dBA, 10.80w .90 Amp, 12v DC, 3+4 pin Molex connectors.
    link below
    http://www.sidewindercomputers.com/del80ffb08123.html
    can anyone point me in the right direction ?
    again sorry about the spam I just need lots of help
    building my new comp I want to get it right the first time
    Thanks again and for putting up with my S***
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    That fan has a resistance of 13.33R (V/I) so you need a rheostat about the same to turn the fan volts down to about 6v.
    A 10R will give you 6.85V minimum, a 15R 5.6V minimum.
    Taking the 10R, power needed is Rheo Resistance * Max Fan Current^2, ie 10*0.9*0.9=8.1W, coming down to 5.2W going to the limit of the allowance Vishay quote for their rheostats.
    God knows where you'll get one from, an electronic solution is best for powerful fans.
  3. BURNER-X
    1 Mar 2002
    Ummm thanks
    So I can't get one for this fan?
  4. eaterofpies
    eaterofpies What's a Dremel?
    12 Feb 2002
    u might be able to get 1 but i dont know where also it would probably be big and expensive a better solution is to use one of the solutions on cpemmas site here
    sorry to guys at bit-tech for plugging cpemmas site so much i just like his solutions thats all :D
  5. BURNER-X
    1 Mar 2002
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Well, Vishay say the 15R 12.5W one (66101.pdf) will carry 0.91 amps, your fan's 0.90 amps top speed, so that's very safe, the 10R even safer.
    The 25W and 50W are overkill.
    I think RS (Spares not Shack) do the Vishays if you're in the UK. Cost you though. :eek:
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Don't apologise, its a sign of weakness - John Wayne
    :D
    (The cheques in the post)
  8. eaterofpies
    12 Feb 2002
    good good that will pay for the silver spray paint (for fans) and leave a little bit left over to go towards a dremmel
    :D
  9. BURNER-X
    1 Mar 2002
