Linux more ubuntu troubles
Discussion in 'Software' started by FILTHY1337, 14 Feb 2008.
  1. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    so i have an e 1705 dell lappy, and an addition monitor hooked up but i can only display one at a time. im trying to get a dual head display. How do i do this?
  2. Elv13
    Elv13 What's a Dremel?
    26 Apr 2006
    what is your graphic card and can you post the content of your /etc/X11/xorg.conf file please.
  3. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    gutsy? try going into their display manager (in the settings menu) and seeing if you can just enable it in the gui. if not, you're in for a lot of config file editing.
  4. FILTHY1337
    4 Jan 2004
    ok finally found the menu and it has the option to use it as a secondary monitor but its grayed out as the cars its a basic intel card forgot the model.
  5. notatoad
    25 Jun 2004
    if the option to use it as a secondary monitor is grayed ou tou are going to have to find some new drivers
  6. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    I would head over to the ubuntu forums (there a friendly bunch too) and ask them. There may be a bit of cli use to get it going since intel gfx cards are well supported the best driver is probably already installed.
  7. Elv13
    26 Apr 2006
    look for something like ubuntu intel xinerama on google
  8. FILTHY1337
    4 Jan 2004
    ok dual head display now up and running but i screwed my res on my defult screen,....ran in 1440 900 out of the box now runs 1024. I cant seem to find the proper setting with out it stretching off screen
  9. Elv13
    26 Apr 2006
    can you post your /etx/X11/xorg.conf please
