Motors Morning frost vs You
Discussion in 'General' started by wyx087, 16 Nov 2010.
  1. wyx087
    15 Aug 2007
    how do you tackle frost that covers your car every morning?
    yesterday, i used up a lot of spray to get rid of the frost, totally uneconomical.
    today, i used some warm water and took off the frost immediately. but i don't think i'll work during really cold days.
  2. BRAWL
    BRAWL Dead and buried.
    16 Aug 2010
    You wont work during cold days? >.<
    I use the train :p So I don't suffer the wrath of frost... not yet anyway, even then I intend on having windows that defrost >.<
  3. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    dont chuck water on frosty windscreens, you'll more than likely end up smashing it through
  4. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    This
    Also I would recommend buying a car cover from halfords, they are only about £20 but will save you a lot of hassle in the mornings.
  5. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Yeah, I may not be car-savy, but I know warm water is bad on frosty car windows.
    Personally, I just get in and turn the heater on full chat, along with the heated windscreens etc >.>
  6. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Bike=No frost problems
    though Bike = v-cold fingers so its swings and round abouts.
    When i do have to deal with a frosty morning i get the scraper out and get stuck in, if its really bad then i use those chemical deicers that tesco sell by front door when its cold out.
  7. shigllgetcha
    shigllgetcha Come at me bro
    3 Mar 2008
    ive always used a kettle of warm water
  8. wyx087
    15 Aug 2007
    there's the problem of where to put the windscreen cover. it'll be dripping with water after a while. living in a flat, so get back to my room is a lot of effort.
    it won't be very hot water, just tepid water. should be fine shouldn't it?
    with my car, if i turn on the heater to clear front fog, AC comes on, and cannot be turned off, so together with rear window heating, it'd eat into my battery. being a 7 year old car, don't think 5 mile drive can provide enough power to do this every morning.
    re bikes, you'll also get problem of slippery roads on your 2 wheel. i've had my share of this during secondary school. cars will get you there nice and warm :D
    mvagusta likes this.
  9. Krikkit
    21 Jan 2003
    It should be alright, but the risk is weakened windows. The windscreen should be alright because they're pretty strong glass, but the sidewindows and particularly the boot window will be victim.
    Easiest frost solution is a car/windscreen cover, they go in the boot. :p
  10. Weekly_Estimate
    Weekly_Estimate Gives credit where its due
    1 Feb 2010
    I second this!, Damn my fingers feel like falling off, I don't wear gloves as they get in the way of the controls!, damnittttt:brrr:
  11. BRAWL
    16 Aug 2010
    I see your issue squire... you need a quadbike and waterproofs.
  12. DeadP1xels
    30 Nov 2009
    I had a thick load of ice on my windscreen yesterday morning what was strange is it was only me everyone else was clear not even steamed up!!
    I had to use some super deicer i was in a rush and had no scraper handy
  13. Weekly_Estimate
    1 Feb 2010
    Quad Bikes rule - big fan here, have had a road legal one i bought last year only done 500 miles!, Never passed my test, so i can't really ride it! :duh:
  14. nightblade628
    nightblade628 Minimodder
    10 Dec 2009
    Where hot water REALLY shines is when you're stuck in snow; many mornings, I'd come out to a car stuck in place with just its wheels spinning and unable to go anywhere, so I bought a small shovel and it still didn't work. Bucket of hot water? Ideal.
    As for windows, keep a spray bottle of cold water in the house with you, and spray a light mist on the windscreen - windshield winter cleaning solution mixed in is also good; hot water can be bad for glass, but room-temp water (even cold) is still warmer than the ice itself and it weakens the ice considerably, making it easier to come off with gentle coercion.
  15. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    A scraper and some muscle has always been an effective solution for me. The biggest PITA is when your doors are frozen solid and you cant reach the scraper.
  16. BRAWL
    16 Aug 2010
    Can actually say it's quite tempting myself mate. Got enough arctic warfare kit laying arounda t home, fuel's cheaper, MOT and Tax is cheaper... you're also legally entitled to go off road aswell >.< so if people get in your way, the side of the road is totally good to ride on :p
    Although turning up to work looking like you're going to war in Norway on a Quadbike might not go down to well... haha
  17. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    If it catches me unawares or I just cba, a bottle of salt water works well enough, otherwise it's a cardboard box for the windscreen and a labcoat on each side window :brrr:
  18. mrlongbeard
    31 Jan 2010
    Men come pre-equipped to deal with that wee problem :thumb:
    pimonserry likes this.
  19. Unicorn
    25 Jul 2006
    1. Unlock car.
    2. Open door.
    3. Get in.
    4. Place key in ignition.
    5. Start car.
    6. Turn heater on.
    7. Adjust fan & vents to blow on windscreen at full power.
    8. Turn on heated windscreen, back window and wing mirrors.
    9. ???
    10. Go to work!
    An easy 10 step guide to dealing with frost in the mornings... it takes <5 minutes.
  20. Krikkit
    21 Jan 2003
    That's fine when you have a fancy car that warms itself in 5 minutes and has fancy heated bits, what about the peasants? :p
