Motherboard damage
Discussion in 'Tech Support' started by scq, 6 Aug 2006.
  1. scq
    scq What's a Dremel?
    4 Mar 2005
    Is it really that bad if I accidently scrape off some of the plastic (colored) coating off around the screw holes? A screw was being disagreeable and got stuck during installation. I managed to remove it, but it did take off some of the coating around the screw hole.
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Can you post pics?
  3. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    generaly there are no traces around the screw holes so you should have gotten away with it. Still pictures would be helpfull
  4. scq
    4 Mar 2005
    It's fine now. I got an exchange.
