Build Advice Motherboard mount
Discussion in 'Hardware' started by phoenixck, 23 Sep 2012.
  1. phoenixck
    phoenixck What's a Dremel?
    7 Jan 2012
    I'm not really sure what to call it as google is no help whatsoever, does anyone know of any place that sells (sketchup etc would do) the bit the offset screws go into i.e the bit that the motherboard is mounted to?
  2. Ra1z3r-X
    Ra1z3r-X What's a Dremel?
    14 Sep 2012
    not certain i follow but i think youre refering to the "mobo tray"
  3. ShinyAli
    ShinyAli What's a Dremel?
    14 Sep 2012
  4. Uncle Psychosis
    Uncle Psychosis Classically Trained
    27 Jul 2003
    Do you mean motherboard standoffs?
    They come in different types---screw in, clip in, etc.
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
  6. David
    7 Apr 2009
  7. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    These are not the standoffs you're looking for.
    Move along.
  8. phoenixck
    7 Jan 2012
    Indeed, thank you spreadie got it right, motherboard tray.
    Does anyone know a company that sells them or have a template from a mod or similar that I could use to make one?
  9. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    You can get Lian Li motherboard trays seperately which also usually include the pci card backplane, and some a fan mount.
  10. phoenixck
    7 Jan 2012
    bit expensive........ anybody know the placement of the screws? I.e as a template, the only spare case I have doesn't fit full atx and I'm attempting to make a case that I can use alot longer than the hardware inside lasts (ie room for expansions etc)
  11. Lorquis
    8 Sep 2002
    Put mobo On a bit of paper... draw with a pencil through the holes... template done..
  12. phoenixck
    7 Jan 2012
    and the award for the most obvious solution go to.......
    Just kidding, it was my first though I just hoped a super modder had a template I could put on sticky paper and stick to the metal I'm using.....:dremel:
  13. Lorquis
    8 Sep 2002
    I know, I just figured; why complicate things?
